Error 500
hi guys just done the update (2.2.9.138) and now i get Error 500 code when trying to go to APPS.
same issue here, i'm going to try and do a soft reset.. ill report back shortly
i have reset it back to the version before. restarted the hub. shutdown the hub and still nothing
nothing working for me either, also noticed that the dashboard app link in the menu vanishes when you get the 500 error.
@mike.maxwell thought you might be able to help?
If you see error 500 on multiple pages, it's generally indicative of a corrupted database. First thing to do is take a fresh backup, then run a Soft reset and restore the newly created backup:
https://docs.hubitat.com/index.php?title=Soft_Reset
Hi Bobby,
Already tried this and it hasn't resolved it. It is only on the App page which does it and its only since the update.
Thanks for your feedback. Do you mind sending me a PM with your hub's MAC address and registration email so we can further research?
Will do, FYI i've also just tried again after updating DT to the latest version and it still hasn't work.
If you see this error on apps page, please roll back to a previous version. We'll get a fix into the next iteration.
This worked in my case thanks :smile:
Not sure why it didn't for @darrenmonk87 though?
Can you PM me your hub id? I'll take a look at the engineering logs on the hub.
