If you are not using the power reporting features of the plug, you need to set Parameter #18 to a value of 1 to disable all power reporting. This will eliminate all extra zwave messages and improve your mesh speed.
If you do want to use the power reporting, need to set the limits higher and monitor the events section of each device for excessive reporting until you get it dialed in correctly so it is not spamming reports.
