I'm mostly working with Z-Wave and Zigbee devices. Every once in a while - rarely, but it happens - one member of a scene simply won't respond. For whatever reason. I activate the scene again or manually control the device and it's fine.
The status is always correct in hubitat - e.g., the hub knows that the device didn't do what it was supposed to.
Is there any way to have Hubitat "verify" that the device properly responded to a command, and then re-send the command if it didn't?
