Allow the use of global variable to set bulb color when setting up Lighting Periods.
This will be in the next release. The way it works is you use a String variable with a hex color value in it.
Cool, thanks. While we're on the subject, is there perhaps a way to implement "bulk" updates to devices in the Lighting Periods table, other than re-capture? I have a number of "ganged" lights where there are as many as 8 lights controlled by one activator. I'd like to be able to set, say, the level of all of them to a hub variable without having to select each light individually. I've done it that way, but boy it's a lot of clicks.
Not at present. This is a subject that's on my mind though, as there is a related issue that surfaced: If you use random color, each light gets its own color. I know that doesn't make sense in some use cases, so it sort of brings up the same issue. I don't have a solution yet... Maybe some toggle for 'treat all bulbs the same', where setting one sets them all (and a single random color would apply for all).
