Hi,
I am currently setting up dashboards for family members as guest users. I want some of the functionality to work only when the family member is home, and some of the functionality to work all the time via WiFi. In order to achieve this, as far as I can see, I need to set up two dashboards, one WiFi enabled and one local.
I think it would be neat to have the ability to control WiFi availability per button (instead of per dashboard). That way I would only have to do one dashboard and the local buttons would be disabled/not visible when the user would be outside of the local network, instead of having two dashbaords. Default should be local only and the value should be valid per dashboard, i.e. the same button could be WiFi available or WiFi unavailable depending on in which dashboard I use the button.
Regards,
/Magnus.s
