Enhance Classic Dashboard Outlet Template to Display Power
Please update the Classic Dashboard Outlet template to optionally display the device’s live power attribute while retaining direct on/off control.
Many smart outlets expose both Switch and PowerMeter capabilities, but Classic Dashboard currently requires separate Outlet and Power Meter tiles. A configurable power value in the upper-left corner of the Outlet tile would reduce dashboard space and provide a cleaner interface.
Ideally, the template could also optionally display voltage, amperage, or energy when those capabilities are available.
While this option isn't natively available, you may be interested in try Tile Master. It's available at HPM, and allow the construction of a tile with all these values. I use it, and the icon change when the outlet is on or off.
Not possible. Just went thru tons of threads.
We do not want to install.
We want add power meter, energy meter or voltage to outlet tile
