Enerwave ZWN-RSM1 PLUS—Smart Single Relay Switch Module
Does hubitat support this?
https://enerwaveautomation.com/products/zwnrsm1s/
or the dual one
https://enerwaveautomation.com/products/zwnrsm2/
Both the Enerwave relay modules work with Hubitat. I use the dual relay myself. You will need custom drivers written Eric Maycock (@ericm), which are available from his GitHub:
I put in an RSM2 and it works manually, i.e on1 turns on 1 only, on2 turns on 2 only, and off turns off both. Is there a way to use simple lighting to turn them on and off independently ?
