I just added an Enerwave ZW15RM-Plus outlet. Can anyone tell me what driver they are using if anyone else is using this device? The device manual indicates it can do smart metering to monitor energy usage. I tried selecting the Generic Zwave Switch and Smart Switch (what is the difference between these two?) and both work to turn the lower plug on and off, however I don’t see any energy monitoring with either. Just looking for some guidance from anyone else who may be using these with Hubitat. Thanks!
I found my answers. Moderator please delete this post. Thanks!
Hello Craigspree, I just saw you post and I am wondering if the device driver you posted is still useable. I am not sure what in the Dashboard it should be listed as. Should I select outlet because I just get a ? mark. Thanks in advance.
I think it's still the best driver. I do want to mention I had a lot of trouble with multiple of these devices... they just stopped reporting power usage. I contact the company and they acted like it was a known issue. I experienced it with both HE and ST so I don't think it's my hub.
Yes it’s still usable and I have two of them. If you want to add it to the dashboard then choose to add a tile. Choose the name of the outlet that you called it in Devices and choose Switch and then add.
Power reporting did work for me, however I gave up on these outlets. The fact that they turn off after a power outage made them useless for monitoring appliances. I switched to a zooz power monitor which has worked great, though I do hate that now it’s a dongle.
Hello @kahn-hubitat:
Question: Is your driver applicable to the Enerwave ZW15RM as well as the SM version?
Also, how do I turn debug off on this driver?
I had been using the regular generic zwave plus driver.
However, I just noticed the logs for this device:
