I have three enerwave zw500d that are on smartthings right now using z-wave generic dimmer driver. I tried to move these over to hubitat but unable to do so.
Please advise if you know how to move these enerwave zw500d over to hubitat.
Thanks in advance for your help.
Did you first exclude them from ST before trying to add to Hubitat? With z-wave devices, you first have to exclude them from the network their are joined to and then you can join them to a new network. They can't be joined to two at once.
You first go into HE and open a second tab with the logging window open.
Now put the hub into z-wave exclusion mode, then hit up on the dimmer once. The logs should show that a device was successfully excluded.
Now put the hub in z-wave pairing mode and hit up on the dimmer again. This should join the device to your z-wave network on HE.
Thks, i finally got all zwave migrated over to he.
Only two items left. Arlo and honeywell thermostat.
Arlo might have to go with ifttt for motion sensor status. Honeywell has a solution but i keep getting unauthorized half of the time. Sight
