I have an Enerwave Z-Wave outlet That I was using with ST. I removed it from ST and paired it with Hubitat. No problem there. I changed the driver to Generic Z-Wave Outlet. I can control the device ok. But the indicator light is backwards. In ST it was on when the outlet was on and off when the outlet was off. In Hubitat it is the other way around. I tried changing the setting in the device configuration, but it won't change.
Any suggestions?
I use the zooz outlet driver so I can get power monitoring. Works correct for me with that.
The only driver I see is Zooz Power Switch. It will work, but I don't see any option to change the indicator light.
