Energy Monitoring outlet for multiple things?
What is a good Energy Monitoring outlet for multiple things? I have found them very useful for my computers, refrigerators even the hubitat hub it self to see power usage.
I have a few now that are z-wave but have read that z-wave is not the best network to use if your going to half a bunch of devices.
I have been using the Minoston Z-Wave 800 Series, they work fine but i want to add more of them.
You should consider IotaWatt.
It will allowed you to monitor every circuit in the Electric Box:
plus Voltage
And sure, few local power monitoring outlets placed in strategical places also a BIG help.
I use both the Third Reality Energy Monitoring Plugs and the Switchbot Plug with Energy Monitoring. The Third Reality are Zigbee plugs connected directly to Hubitat. The Switchbot are brought in from Home Assistant.
It's the install that has always kept me away from them.
https://www.amazon.com/dp/B092DBFFBY?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1
Well, If you are not comfortable then don't do it.
But from the other side, installing IotaWatt (or similar device) is much easier than replacing a regular switch with a smart one.
