Enbrighten Zigbee In-Wall Smart Outlet - 43102
This outlet works fine with the generic driver except there is no control for the VERY bright LED.
I looked around a bit for another driver but didn't find one.
Does anyone have a driver for this device that also allows for LED support?
Thanks!
I don't think you can turn the LED off...(I could be wrong but I've never seen it)
@ts1234 ....This is from the online manual from the Jasco website for the 43102 Zigbee outlet. Press the program button 10 times quickly to cycle through the LED options.....
Enbrighten 43102
I'm old and forgetful but swore I could with HS4. However, at that time I did turn off the equipment connected to it in a nighttime routine. I now would rather the Apple TV and TV powered up 24/7. I used these to build out my base Zigbee mesh and will admit the other three are all in places that almost never get used...
Thanks...there's always this little thing call electrical tape that blocks LED lights really well. :wink:
Well duh on my part Sakman! THANKS!!!!
