I just bought an Enbrighten zigbee dimmer switch 43080 and 2 add on switches.
Everything works fine except that the lights will flicker when the dimmer is set to less that 45 percent. The manual dimmer that I replaced worked just fine all the way down to almost nothing. Is there anything I can do other than try a different brand of switch. I don't want to replace the 10 lights in the ceiling.
