On most switches (I have GE Embrighten) there is that blue indicator light when can be set to either always off, on when on, or on when off. Can this setting be changed using rule machine?
Every switch in the house has that setting to "Always off", but I use the double-tap functionality on one of the switches to hold my garage door open -> Double tap up and it turns on the "Hold Garage Door" smart switch which prevents the garage door from automatically going down.
What I want is to turn that indicator on whenever the garage door hold is on. And I can use a simple If statement:
If (Garage Hold = On and Switch = On) then "indicator light on when on"
else if (Garage Hold = On and Switch = Off) then "indicator light on when off"
else "indicator light always off"
Thanks for any input!
