EcoSmart Zigbee Bulb Type
I'm attempting to move to Hubitat from another system and I have a large number of EcoSmart A19 Tunable White Zigbee bulbs (Home Depot brand). I factory reset them by turning them on and off 6 times in 5 seconds and paired a couple to Hubitat just fine. They add as "Advanced Zigbee CT Bulb". With that Type, I can turn the bulb off using the Device command page, but it won't turn on when I click the on button on that page. I added a second bulb and changed the Type to "Generic Zigbee CT Bulb (dev)" and that allows me to turn the bulb on and off. For both of them, when I add them to a dashboard, it shows a red shaded button with a :(. When I click on the three dots, it says "Missing Attributes: level". I've seen a couple other posts reference having these working. What can I try to get these going?
[[meta: You might want to include what release your hub is running, along with the hub model]]
I have half a dozen each of the Ecosmart BR30 and A19. All are using the Advanced Zigbee CT Bulb type. Running the latest 2.3.9 (and latest beta 2.4.0), I can turn them on or off just fine with the command on the device page.
One thing I remember - I first had to use the Set Level command to 100 before it would work (even though it showed 100 in the settings box under the command).
Thanks, that seems to have made them happy. I typed 100 under set level and pushed that button on the device page. After that they are turning off and on and working on dashboards with the Advanced Zigbee CT Bulb type.
