Hello all,
As stated, Ecobee Suite Quiet Time Helper activates then deactivates almost immediately (within 1 second).
I've configured a virtual switch to allow it to activate and deactivate, and I control the switch status with a basic rule.
Here is the Quiet Time Helper app config:
Here is the output of the Quiet Time Helper app:
Here is the output of the switch log:
(note that I manually set it to on and off as to not involve the Basic Rule).
Why is the Quiet Time Helper immediately reverting? Has anyone experienced this?
Thanks!
[update]
After further research it appears that the only way to allow this to work is to set the fan to on in the Comfort Setting. The best thing I think I can do if this is the case is then to create a comfort setting dedicated to the fan being off, then correlate the Quiet Time Helper.
So, it appears that setting the fan to "on" during "heat" will bypass the Quiet Time fan off. So, the problem persists... Although the fan on mins/hour is respected, the fan being always on is not awesome. I must be missing something obvious, because this flat out doesn't work.
