Ecobee integration not showing state
@mike.maxwell I think I saw on another post you were going to be looking into thermostat stuff today, and wanted to report an issue I have been having with the built in Ecobee integration driver.
I noticed that in my dashboard, my thermostat tiles always say the thermostat is idle, and never engages the Heating template. Looked in the device driver, and noticed that the driver always says idle, so looks like dashboard is not the issue.
I thought maybe the integration lost it's connection, so I changed the heat point from 69 to 75 using the driver. The heat point on the thermostat changed right away to reflect the new 75 degree setting, but still reported idle. I waited until the house got to 72 just in case it was in some kind of pre-heat mode or something. Driver never reported back anything other than idle.
This screenshot is from while the heat was engaged and heating.
Thank you
It has been a few years and I have nearly the same issue. I had version 2.3.0.124 and it was identical. I upgraded to 2.3.0.130 and it is nearly the same. I did see the icon on the dashboard go RED saying it was heating, but then when the heater stopped, it did not go gray. I closed the dashboard and reopened it was gray. I increased the desired temp on the thermostat and the heater came on, but the icon did not change the set temp or turn red. I closed the dashboard and reopened, still gray and still shows the old set temp.
Anyone have the fix yet?
Ecobee integration not showing state and updating
Thank you, Charlie
