Ecobee Integration error
I have noticed the following 'Internal Server Error' in my log using the built in Ecobee Integration:
[app:2167] groovyx.net.http.HttpResponseException: Internal Server Error (getCurrentFurnaceStatus)
[app:2167] HttpResponseException groovyx.net.http.HttpResponseException: Internal Server Error, 500 polling ecobee pollAttempt:1, isThermostatPolled:false, isSwitchesPolled:true, [status:[code:14, message:Authentication token has expired. Refresh your tokens. ]]
[app:2167] java.net.SocketTimeoutException: Read timed out (getCurrentFurnaceStatus)
I reset my Ecobee credentials in the app and they errors continue? I have not made any changes in my Ecobee setup. Is this an error in the latest firmware (2.0.5.114), or do I need to correct something?
Thanks.
Nothing for you do, I don't think. I'm getting the same errors. Ecobee's API is very unreliable. I think the new getCurrentFurnaceStatus is a fix to a bug I reported. My guess is the polling maybe getting throttled. Just a guess though.
Not sure if this is also relevent but since doing this update as well me Ecobee custom parameter doesn't work anymore in my rules using Rule Machine.
Same here, ecobee integration works fine expect for this logging error issue.
I'll throw my hat into the ring on this one too. Integration is working fine, but getting bursts of these errors from time to time.
It all seemed to break when I did the 2.5 update. I reverted back to 2.04 and it is working better now.
Same errors here, logs are below. My hub actually locked up last night, not sure if ecobee was the reason.
How are we supposed to tell what the app is? Hubitat troubleshooting tools are lacking, I mean looks like ecobee, but at the top of the log it only said google home & inovelli plug
app:1442019-02-28 11:31:20.439 pm errorUnhandled exception java.net.NoRouteToHostException: No route to host (Host unreachable) in ecobee polling pollAttempt:1, isThermostatPolled:false, isSwitchesPolled:true
app:1442019-02-28 11:20:02.226 pm errorgroovyx.net.http.HttpResponseException: Internal Server Error (getCurrentFurnaceStatus)
app:1442019-02-28 11:20:00.399 pm infoHttpResponseException groovyx.net.http.HttpResponseException: Internal Server Error, 500 polling ecobee pollAttempt:1, isThermostatPolled:false, isSwitchesPolled:true, [status:[code:14, message:Authentication token has expired. Refresh your tokens. ]]
app:1442019-02-28 09:50:02.269 pm errorgroovyx.net.http.HttpResponseException: Internal Server Error (getCurrentFurnaceStatus)
app:1442019-02-28 09:50:00.551 pm infoHttpResponseException groovyx.net.http.HttpResponseException: Internal Server Error, 500 polling ecobee pollAttempt:1, isThermostatPolled:false, isSwitchesPolled:true, [status:[code:14, message:Authentication token has expired. Refresh your tokens. ]]
--- Loading Past Logs... ---
