Ecobee Integration: Application has been revoked
My Ecobee suddenly stopped reporting its status today and after looking at the Hubitat logs, I see these suspicious messages, which look a bit troubling. The app in question is the built-in Ecobee integration. Anyone else having problems with Ecobee?
Exception getEcobeeDevices: 500, e:groovyx.net.http.HttpResponseException: status code: 500, reason phrase: Internal Server Error, data:[status:[code:2, message:Not authorized. Application has been revoked.]]
app:112023-08-02 08:10:00.876 PMerrorEcobee poll failed for other reason than expired authToken
app:112023-08-02 08:10:00.875 PMinfoHttpResponseException groovyx.net.http.HttpResponseException: status code: 500, reason phrase: Internal Server Error, 500 polling ecobee pollAttempt:1, isThermostatPolled:false, isSwitchesPolled:true, [status:[code:2, message:Not authorized. Application has been revoked.]]
Mine works fine.
I did get this in the logs but I could change the setpoint successfully.
Thanks for checking, Even though the integration was showing as active and authenticated, I forced a logout and re-authentication and it appears to be working again. I've sent a message to Ecobee for them to check their logs on their side as well since the error was coming from them.
