Hi
I’m trying to find a way to trigger an action when the volume on an Echo Speaks connected echo device goes above a certain level during certain modes.
I can see the volume value when I view the device information, but I can’t see how I would use that as a trigger (either in ES or RM).
Could someone point me in the right direction please?
Thanks!
There’s probably a way in both of those, but in webCoRE it’s really simple to select the device and level as a trigger....
Thanks, I’ll take a look.
When you set your trigger use custom attribute and select the Echo device. You can then trigger on Volume.
You can do this in RM or Webcore.
Thanks. I have something set up in Webcore now, just evaluating it to see if I have it set up right. I’ll take another look at RM though too.
Ok, problem solved with Webcore, and very straightforward, works perfectly. Thanks for the suggestion
system
Closed
7
