Echo speaks - I can't quite get it
I'm trying to install echo speaks. I get it installed but it tells me that I'm not signed into Amazon. I use the option that is supposed to sign in to Amazon and instead it goes to heroku and says there is nothing here. Like that app did not get installed. I have removed the echo speaks app several times and reinstalled it with the same results. I am using the package manager to install echo speaks. Somewhere I am doing something wrong but I cannot figure out what. Any ideas on how to correct this?
After installing the HPM package you need to install the server package separately. Follow instructions in this link.
Heroku is a separate app that does not (and apparently cannot) be installed automatically. Those instructions linked by terminal3 walk you through those steps. Follow them carefully, they can be a bit tricky, especially if you just try to ad-lib things.
you are correct. I was messing up on the part where I was to name the app. I followed the instructions very carefully and this time it worked. I did not have those instructions on my first 3 attempts at installing. Thanks for your help.
I think this was my main issue. I missed a step. All good now.
