Easy way to clear out scheduled jobs on devices?
Long story short, some devices I've been using for years are just now causing all sorts of chaos since I tried using hub mesh. Apparently the drivers aren't written well and now there is craziness happening on both my hubs. I've determined that another Hubitat now supports these devices with native drivers, but the problematic "scheduled jobs" are stuck with the new device after creating a virtual device and using "Swap Device" to temporarily keeps all my rules working while I re-paired the devices using Hubitats built in drivers.
Ok that was still long. Anyway, is there an endpoint I can use to simply wipe out scheduled jobs without having to convert every one of these temporarily to "device" to clear the scheduled jobs?
I believe that the Scheduled Jobs tab in the Logs screen has the ability to delete a single scheduled job.
Yes Logs > Scheduled Jobs (wait a minute for it to load), then you can search by device or job name (if they are all the same schedule name / method use that to search). Then you can just trash them all.
Thanks guys :pray:
