Each hub reboot is spawning another instance of my MQTT app
Ok, I'm stumped. Need some input from smarter developers than me.
What I'm seeing is that SOMETIMES (not always) on a reboot of my dev hub, another instance of my MQTT app seems to be spawning. Not sure why, or even how really. I wouldn't know how to do that on purpose if I wanted to... lol
I have a debug message that runs in initialize(). On a clean power up of the hub, I see it initialize 1x as expected.
Do a reboot from the interface on the hub, next boot I see initialize() called 2x. Next reboot, 3x. Etc. Until I do a shutdown and pull power.
Anyone see this before? Any tips on how I can track down why it is happening?
What does your Initialize method do? And do you call it from anywhere else, especially if it or a calling function are scheduled for a future execution?
All good questions.
It does the device event subscriptions, a bunch of device property parsing, and then MQTT subscriptions in a driver. I do see the initialize() code complete in all cases (have a debug msg at the end of initialize()), so it definitely is not getting stuck in there.
If I run the method from somewhere else (I can manually trigger it from the driver, or edit the app and re-save) it only runs 1x as expected.
I just refactored the code a bit, which looks like it will work around the issue to some extent. I made initialize just set an atomicState to "initializing" if not already = to that, and schedule the rest of the code that used to run in initialize() in a different method.
I still see initialize() getting hit 2x on a reboot, but the actual init code only gets run once - so it looks like the atomicState check is helping to prevent massive code runaway at least.
I think you're ping ponging on this, from a very quick glance:
if (evt.name == "init") {
initialize()
return;
Your app runs initialize. And the driver runs its initialize, which seems to cause an app initialize. If you had more drivers, I suspect it would just grow linearly. Also seems like they're racing-- depending on whether your app has subscribed yet before the driver gets there.
I thought I checked that already, but I'll check again as that sounds completely logical/reasonable...
Yup. I completely screwed that up. At least I know what to go fix now....
Thank you @tomw . I would have sworn I checked that... But obviously not. I guess I wasn't as methodical as I thought in my troubleshooting.
It also explains why my workaround - breaking the code into a separate method and using runIn - worked. Initialize still ran multiple times, but the schedules just overwrote each other so the other method only ran once as intended.
