What I want to do is loop through a list of presence devices, and allow options set for each. I haven't messed with dynamic pages, but I haven't seen anything about dynamic inputs, like:
n = 0
presenceDevice.each{
n++
input "person{$n}","text", "Input some text"
I don't care whether the name of the variable is dynamic, or it uses a map, but I need a different "text" for each person.
Any way to get to my goal on this?
Sure, that will work as you expect.
Except your syntax is wrong:
input "person${n}", ...
or even just
input "person$n", ...
Literally LOL...
Thanks.
edit: I totally made it up.... So Im shocked.
Stuck again. So I do:
But when I try to do something like:
log.debug person${n}
I get an error. What's the trick?
Several years ago I worked with another community member in ST land on an alarm integration where we used a dynamic page with dynamic inputs. Here is the code if you want a working example.
Basically it prompts for the number of child device to create and then allows you to define details on those child devices.
