Dynamic Multi-Page App that edits a Nested Map
Hey, all! Hoping someone can help me out here. I'm trying to develop a Hubitat App that has the following functionality :
  • User adds entries into a Nested Map (map of maps; no problem here, this is done)
  • The app creates a button for each entry (or key) of the high-level Map
  • The button goes to a new page that lists the information of the Nested Map
My idea was to :
  • Do a ".each" loop to make a 'href' per high-level map key
  • Use params function within the 'href' to pass a parameter which would be the Key of the high-level map.
  • Have the 'href' reference a page that accepts the key as the passed parameter and pulls the information from the nested map
This isn't working for me, though. Can anyone assist?
For anyone who might come across this post. I figured it out!
I used this post as a reference :
Here is my solution's code:
 *  Example of passing params via href element to a dynamic page
 *  Copyright 2015 SmartThings
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
definition(
    name: "href params example v2",
    namespace: "Testing",
    author: "Mike Dam",
    description: "Testing Params & dynamic pages",
    documentationLink: "TBD",
    singleInstance: true,
    installOnOpen: true,
    importUrl: "github... TBD",
    videoLink: "Youtube Tutorial video... TBD",
    iconUrl: "",
    iconX2Url: "")
// Required Library Imports
import java.util.LinkedHashMap
// Required Classes
def installed() {
    log.debug "installed()"
    resetVariables()
def resetVariables(){
    atomicState.nestedMaps = [:] //Hashmap, Key = Name | Value =  [Height, Weight, Gender]
    atomicState.orderList = [] //List, Index is order the keys are called on the main page
    updated()
def updated() {
    log.debug "updated()"
def uninstalled() {
    log.debug "uninstalled()"
Notes I found during experimentation:
1) Preferences needs to hold "pages" (ex: "page(name: "moveLogicMethod")") that are the same as the Methods you add below if the Method either:
    a) has page within it
    b) is used as the "nextPage:" for a page
    c) is used as the "page:" for a href
2) If you are referencing a Method as a page (see note #1) in any way, you need to ensure that Method itself either:
    a) has a page within it
    b) finishes by referencing a method who has a page within it
3) You must add the pages as a Method instead of within preferences if either:
    a) they are called directly by a method (ex: "mainPageMethod()")
    b) they do utilize params being passed to it from an href
4) The page you want to start on (look at upon starting the app) should be "top" of the preferences, even if it just references a Method containing the actual page.
5) When listing params in the href, they must be in the form of a map, even if only 1 variable. Examples:
    a) params: [key : mapKey, move : "down"]
    b) params: [key : mapKey]
6) The Method being called doesn't need to use "param" as the input variable. Example:
    The href :
        href(name: "toMoveUp", title: "Move Up", page: "moveLogicMethod", params: [key : mapKey, move : "up"], description: "↑", width: 2)
    The method :
        def moveLogicMethod(differentName) {
            def name = differentName.key
            def upOrDown = differentName.move
7) Pages within Methods must be Dynamic Pages.
8) You must fill in all required fields prior to hitting "back" in the browser OR using an href to go to another page. It is for this reason, I made an "error page" saying the required information isn't inputted ot continue, forcing the user to go back and fill in the data. In doing this, I allow the browser back button, the href "cancel" button, and href "delete" button to work without the fields to be filled in.
9) Design UI to have "cancel" and "next page" buttons appropriately. This is because :
    a) "Done" usually goes to the last page. This does not work if the last page was generated by a Method. In that case, use "nextPage:" and use that to go to the Method that was the last page instead.
    b) The browser's back button doesn't work when the last page was Method generated... in that case, make an "cancel" href that references the last page that was generated by a Method
preferences {
    page(name: "mainPageMethod")
    page(name: "addPage", title: "Add Page", nextPage: "addLogic"){
        section {
            input "nameInput", "text", title: "Name", required: false, submitOnChange: true
            input "heightInput", "number", range: "0..99", title: "Height in inches", required: false, submitOnChange: true
            input "weightInput", "number", range: "0..999", title: "Weight in lbs", required: false, submitOnChange: true
            input "genderInput", "enum", title: "Gender", options: ["Male", "Female"], required: false, submitOnChange: true
            def keys = state.orderList ?: ["not null"]
            if (keys.contains(nameInput) || nameInput == null)
            {paragraph ("Name is required and must be unique.")}
            paragraph ("To save, hit 'Next'")
            href(name: "cancelAdd", title: "Cancel Add", page: "mainPageMethod", description: "Go back to Main Page", width: 2)
    page(name: "editPageMethod1")
    page(name: "editPageMethod2")
    page(name: "addLogic")
    page(name: "editLogic")
    page(name: "deletePageMethod")
def mainPageMethod() {
    app.removeSetting("nameInput") //removes unwanted variables saved to settings
    app.removeSetting("heightInput") //removes unwanted variables saved to settings
    app.removeSetting("weightInput") //removes unwanted variables saved to settings
    app.removeSetting("genderInput") //removes unwanted variables saved to settings
    dynamicPage(name: "mainPage", title: "Main Page", uninstall: true) {
        section {
            //the List is just to give order to the entries in the higher level map
            state.orderList.eachWithIndex { mapKey, i ->
                paragraph("<h2 style='border: 1px solid'>") // could also use "hr sytle"... "div style" doesn't work for some reason
                paragraph("#${i+1}) Name: $mapKey | Height: ${state.nestedMaps[mapKey]['Height']} | Weight: ${state.nestedMaps[mapKey]['Weight']} | Gender: ${state.nestedMaps[mapKey]['Gender']}")
                href(name: "toEditPage", title: "Edit", page: "editPageMethod1", params: [key : mapKey], description: "Edit ${mapKey}", width: 4)
                if(state.orderList.indexOf(mapKey) != (state.orderList.size()-1)){
                    href(name: "toMoveDown", title: "Move Down", page: "moveLogicMethod", params: [key : mapKey, move : "down"], description: "↓", width: 2)
                } else {paragraph("", width: 2)}
                if(state.orderList.indexOf(mapKey) !=0){
            href(name: "toAddPage", title: "Add Entry", page: "addPage", description: "Add an entry into the Nested Maps")
//checks if all inputs are provided, if not, goes back to add page. If good, saves data and goes back to main page.
//I use these pages to do the saving & not auto-save as the info is inputted into the edit/add pages since I don't want partial info to be inputted, info saved, and then the app exited, making the entry only partially entered.
def addLogic() {
    if (keys.contains(nameInput) || nameInput == null || heightInput == null || weightInput == null || genderInput == null){
        dynamicPage(name: "ErrorPage", title: "Error Page") {
            section{
                paragraph "Fill in all fields. Name must also be unique to add a new entry."
    else
        state.orderList.add(nameInput)
        state.nestedMaps[nameInput] = [Height: heightInput, Weight: weightInput, Gender : genderInput]
        mainPageMethod()
//checks if all inputs are provided, if not, goes back to edit page. If good, saves data and goes back to main page.
def editLogic(){
    if (heightInput == null || weightInput == null || genderInput == null){
        dynamicPage(name: "ErrorPage", title: "Error Page", nextPage: "editPageMethod2") {
            section{
                paragraph "Fill in all fields."
    else
        mainPageMethod()
//required a intermediary Method since "Edit Logic" goes to "editPageMethod2" if there is an error (missing data) and due to that "editPageMethod2" can't have "params" as an input. Due to this, I use this Method to shift the param from the last page into a setting and have the next step reference the setting.
def editPageMethod1(params) {
    def name = params.key
    app.updateSetting("nameInput", name)
    editPageMethod2()
def editPageMethod2() {
    dynamicPage(name: "editPage", title: "Edit Page", nextPage : "editLogic") {
        section{
            paragraph ("Changing values in Nested Map for ${nameInput}")
            input "heightInput", "number", range: "0..99", title: "Height in inches", required: false, submitOnChange: false, defaultValue : state.nestedMaps[nameInput]['Height']
            input "weightInput", "number", range: "0..999", title: "Weight in lbs", required: false, submitOnChange: false, defaultValue : state.nestedMaps[nameInput]['Weight']
            input "genderInput", "enum", title: "Gender", options: ["Male", "Female"], required: false, submitOnChange: false, defaultValue : state.nestedMaps[nameInput]['Gender']
            href(name: "toDeletePage", title: "Delete", page: "deletePageMethod", params: [key : nameInput], description: "Remove ${nameInput} from nested map", width: 2)
            href(name: "cancelEdit", title: "Cancel Edit", page: "mainPageMethod", description: "Go back to Main Page", width: 2)
//Could of just referenced the setting "nameInput" here, but wanted to use params for testing & experience
def deletePageMethod(params) {
    state.nestedMaps.remove(params.key)
    state.orderList.remove(params.key)
    mainPageMethod()
//Used a variable "move" provided through param to determine what happens. This could have been 2 methods, but I was able to combine them into 1.
    index = state.orderList.indexOf(name)
    state.orderList.removeAt(index)
    if (upOrDown == "up"){
        state.orderList.add(index-1, name) // add nameInput just before index (index-1)
    if (upOrDown == "down"){
        state.orderList.add(index+1, name) // add nameInput just before index (index+1)
    mainPageMethod()
  1. Preferences needs to hold "pages" (ex: "page(name: "moveLogicMethod")") that are the same as the Methods you add below if the Method either:
  2. If you are referencing a Method as a page (see note #1) in any way, you need to ensure that Method itself either:
  3. You must add the pages as a Method instead of within preferences if either:
  4. The page you want to start on (look at upon starting the app) should be "top" of the preferences, even if it just references a Method containing the actual page.
  5. When listing params in the href, they must be in the form of a map, even if only 1 variable. Examples:
  6. The Method being called doesn't need to use "param" as the input variable. Example:
    The href :
    The method :
  7. Pages within Methods must be Dynamic Pages.
  8. You must fill in all required fields prior to hitting "back" in the browser OR using an href to go to another page. It is for this reason, I made an "error page" saying the required information isn't inputted ot continue, forcing the user to go back and fill in the data. In doing this, I allow the browser back button, the href "cancel" button, and href "delete" button to work without the fields to be filled in.
  9. Design UI to have "cancel" and "next page" buttons appropriately. This is because :
New page in the Hubitat Developer Docs spells out much of the above.
