Dumb Dimmer with Smart On/Off
Is it possible to use this Switch to use as the dimmer but have a smart on/off switch in a 3 way configuration? I checked the Zooz ZEN76 and the literature states that it can't be wired with a dimmer. Are there any smart switches that can connect to a dumb dimmer?
Lutron Sunnata Touch Dimmer Switch with Wallplate with LED+ Advanced Technology, for LED and Incandescent, 3 Way/Multi Location, STCL-153MW-WH, White - Amazon.com
All my three-way configs use the smart zwave dimmer as the main switch, and then I use a standard on/off switch for the other remote switch, that just flips the traveler on the smart switch.
Thats what it seems I will have to do. I was hoping it could work the other way since I was a fan of the touch slide to dim the lights.
Do you know if it is possible to have it the other way?
