Drivers for Sylvania & OSRAM Lightify branded bulbs & light strips
Looking for driver code for Sylvania Smart+ RGBW zigbee bulbs & SYLVANIA SMART+ (OSRAM Lightify RGBW) ZigBee indoor Color Changing Light Strip..
Right now they are generic and I am unable to utilize the RGB on the light strip or to change colors of the bulbs as they are currently super glitchy. Specifically when I change the color on the dashboard, it changes right back, etc.
I have the same bulbs and use the Generic Zigbee RGBW Light driver (built in) without issues.
Which driver are you using?
Generic zigbee RGBW for bulbs and Generic zigbee CT bulb (dev) for the light strip.
This driver will not let you change colors. It can only change color temperature (i.e. Kelvin value).
I have used the generic zigbee rgbw driver with Lightify A19 bulbs in the past, and it has worked fine.
Ok, I switched them. Will see how that works rather than the driver it first chose. Thank you.
I have the Lightify outdoor path lights and use the built-in RGBW driver successfully for them.
Did this help you?
No separate white. White is.a combo off all.for these change to Generic rgb
Or the Advanced Zigbee RGB driver which has been working well with mine.
Gonna add this as I just had to change to a new controller since my old one was acting up. I couldn't get color until I remembered to hit CONFIGURE. Then it started working properly. Just added this in case someone else has a similar issue down the road.
Ok so I ended up switching to the Generic Zigbee RGBW Light driver and I also tried the Advanced driver. I do not see a difference in UI friendliness. When I enter the device off of the dashboard it is just difficult to use but at least has an RGB value posted. Now I can match them by number if needed. Would love to see this as much of an intuitive color wheel with white being selectable as a warm white, or cool white, etc.. Just easier to use. But this way I suppose you are getting more choices! Not complaining at this point.. lol.. Just trying to still learn and get comfortable.
