Would like to report a small bug/oversight maybe for the Dimmer driver. I just replaced the 3-way switch connected to a zen72 dimmer with a momentary toggle, went into the device page and switched from "Toggle On\Off Switch [DEFAULT]" to "Momentary Switch (ZAC99)" and after testing, things didn't appear to be working correctly. I had looked at the settings before and thought there were more options so I checked and there are 4 options for parameter 19:
3-Way Switch Type
Parameter 19: Choose the type of 3-way switch you want to use with this dimmer in a 3-way set-up. Changing this setting can allow you to control brightness and dim the light from both 3-way locations. Use a regular momentary switch (like the Zooz ZAC99 accessory switch) if value is set to 2.
Values: 0 – regular mechanical 3-way on/off switch, use the connected 3-way switch to turn the light off or on to the last brightness level, dimming only available from the Zooz Z-Wave dimmer and from the hub (or through voice control if smart speaker is integrated with your Z-Wave hub); 1 – regular mechanical 3-way on/off switch, tap the paddles once to change state (light on or off), tap the paddles twice quickly to turn light on to full brightness, tap the paddles quickly 3 times to enable a dimming sequence (the light will start dimming up and down in a loop) and tap the switch again to set the selected brightness level; 2 – momentary switch, click once to change status (light on or off), click twice quickly to turn light on to full brightness, press and hold to adjust brightness (dim up / dim down in sequence); 3 – momentary switch, click once to change status (light on or off), click twice quickly to turn light on to full brightness, press and hold to adjust brightness (dim up / dim down in sequence but always reduce brightness after double click). Default: 0.
Size: 1 byte dec
So then I switched to the Basic Z-Wave tool driver and got the current value for param 19 and it was 1 which is the second 3-way option. I used that driver to set param 19 to value 3 then switched back to your driver and everything is working as expected. All of my switches are firmware 1.03.
Love the drivers, very easy to configure them and love the switches as well! Thanks!
