UPDATE
Added ZSE70: Zooz 800 Series Z-Wave Long Range Outdoor Motion Sensor ZSE70 800LR | - The Smartest House
If you already have the package installed, update first then select Modify from the HPM main screen to add/change what drivers you have installed from the package
Version [1.2.2] - 2024-06-28
- Added ZSE70 Outdoor Sensor to package
- Fixed install sequence so device will fully configure at initial pairing
- Update library and common code
