Still not working :
dev:2902023-08-23 16:12:09.211errorjava.lang.NullPointerException: Cannot get property 'numEps' on null object on line 191 (method configure)
dev:2902023-08-23 16:11:42.086infostate.configState was removed...
dev:2902023-08-23 16:11:42.085infostate.notPresentCounter was removed...
dev:2902023-08-23 16:11:42.084infostate.driverVersion was removed...
dev:2902023-08-23 16:11:42.083infostate.stats was removed...
dev:2902023-08-23 16:11:42.082infostate.lastRx was removed...
dev:2902023-08-23 16:11:42.081infostate.modelGroup was removed...
dev:2902023-08-23 16:11:42.080infostate.lastTx was removed...
dev:2902023-08-23 16:11:41.210infoany scheduled jobs were deleted...
dev:2902023-08-23 16:10:16.086debugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DA1F 01 00 0000 11 01 002E82, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DA1F, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:11, direction:01, data:[00, 2E, 82]]
dev:2902023-08-23 16:09:56.375debugTuya Temperature Humidity Illuminance LCD Display with a Clock NOT PARSED : [raw:DA1F01000026DFFF420F9BDD782C13BDDD782C12BEDD782C12, dni:DA1F, endpoint:01, cluster:0000, size:26, attrId:FFDF, encoding:42, command:0A, value:Ýx,½Ýx,¾Ýx,, clusterInt:0, attrInt:65503]
dev:2902023-08-23 16:09:56.369debugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:DA1F01000026DFFF420F9BDD782C13BDDD782C12BEDD782C12, dni:DA1F, endpoint:01, cluster:0000, size:26, attrId:FFDF, encoding:42, command:0A, value:Ýx,½Ýx,¾Ýx,, clusterInt:0, attrInt:65503]
dev:2902023-08-23 16:09:56.294debugTuya Temperature Humidity Illuminance LCD Display with a Clock Tuya check-in message (attribute 0001 reported: 44)
dev:2902023-08-23 16:09:56.286debugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:DA1F0100001801002044E2FF201FE4FF2000, dni:DA1F, endpoint:01, cluster:0000, size:18, attrId:0001, encoding:20, command:0A, value:44, clusterInt:0, attrInt:1, additionalAttrs:[[value:1F, encoding:20, attrId:FFE2, consumedBytes:4, attrInt:65506], [value:00, encoding:20, attrId:FFE4, consumedBytes:4, attrInt:65508]]]
dev:2902023-08-23 16:09:56.252debugTuya Temperature Humidity Illuminance LCD Display with a Clock Tuya cluster confirmation for command 0x24 response 0x00 data = [24, 00]
dev:2902023-08-23 16:09:56.246debugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DA1F 00 00 0000 0B 01 2400, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DA1F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[24, 00]]
dev:2902023-08-23 16:09:56.146debugTuya Temperature Humidity Illuminance LCD Display with a Clock sending time data : [he cmd 0xDA1F 0x01 0xEF00 0x24 {000864E6214464E62F54}, delay 2000]
dev:2902023-08-23 16:09:56.144traceTuya Temperature Humidity Illuminance LCD Display with a Clock now is: 1692803396143
dev:2902023-08-23 16:09:56.134debugTuya Temperature Humidity Illuminance LCD Display with a Clock time synchronization request from device, descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DA1F 01 00 0000 24 01 002D, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DA1F, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:24, direction:01, data:[00, 2D]]
dev:2902023-08-23 16:09:56.128debugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DA1F 01 00 0000 24 01 002D, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DA1F, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:24, direction:01, data:[00, 2D]]
dev:2902023-08-23 16:09:53.102warnTuya Temperature Humidity Illuminance LCD Display with a Clock warning: temperature alarm upper limit reported by the device (0.0 C) differs from the preference setting (39.0 C)
dev:2902023-08-23 16:09:53.098traceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=4 dp=10 fncmd=0 fncmd_len=1 (index=0)
dev:2902023-08-23 16:09:53.093debugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DA1F 01 00 0000 02 01 009B0A04000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DA1F, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 9B, 0A, 04, 00, 01, 00]]
dev:2902023-08-23 16:09:53.002infoTuya Temperature Humidity Illuminance LCD Display with a Clock battery is 0 %
dev:2902023-08-23 16:09:52.997debugTuya Temperature Humidity Illuminance LCD Display with a Clock getBatteryPercentageResult: rawValue = 0 -> 0%
dev:2902023-08-23 16:09:52.994traceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=4 dp=4 fncmd=0 fncmd_len=1 (index=0)
dev:2902023-08-23 16:09:52.986debugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DA1F 01 00 0000 02 01 009A0404000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DA1F, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 9A, 04, 04, 00, 01, 00]]
dev:2902023-08-23 16:09:52.886infoTuya Temperature Humidity Illuminance LCD Display with a Clock Temperature scale reported by device is: Celsius
dev:2902023-08-23 16:09:52.884traceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=2 dp=9 fncmd=0 fncmd_len=4 (index=0)
dev:2902023-08-23 16:09:52.876debugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DA1F 01 00 0000 02 01 00990902000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DA1F, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 99, 09, 02, 00, 04, 00, 00, 00, 00]]
dev:2902023-08-23 16:09:52.781infoTuya Temperature Humidity Illuminance LCD Display with a Clock illuminance is 0 Lux
dev:2902023-08-23 16:09:52.773traceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=2 dp=3 fncmd=0 fncmd_len=4 (index=0)
dev:2902023-08-23 16:09:52.766debugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DA1F 01 00 0000 02 01 00980302000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DA1F, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 98, 03, 02, 00, 04, 00, 00, 00, 00]]
dev:2902023-08-23 16:09:52.228warnTuya Temperature Humidity Illuminance LCD Display with a Clock NOT PROCESSED Tuya cmd: dp=8 value=125 descMap.data = [00, 95, 08, 02, 00, 04, 00, 00, 00, 7D]
dev:2902023-08-23 16:09:52.225traceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=2 dp=8 fncmd=125 fncmd_len=4 (index=0)
dev:2902023-08-23 16:09:52.215debugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DA1F 01 00 0000 02 01 0095080200040000007D, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DA1F, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 95, 08, 02, 00, 04, 00, 00, 00, 7D]]
dev:2902023-08-23 16:09:51.927warnTuya Temperature Humidity Illuminance LCD Display with a Clock ignored invalid humidity 131 (131.0)
dev:2902023-08-23 16:09:51.918traceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=2 dp=2 fncmd=131 fncmd_len=4 (index=0)
dev:2902023-08-23 16:09:51.909debugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DA1F 01 00 0000 02 01 00940202000400000083, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DA1F, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 94, 02, 02, 00, 04, 00, 00, 00, 83]]
dev:2902023-08-23 16:09:51.804warnTuya Temperature Humidity Illuminance LCD Display with a Clock NOT PROCESSED Tuya cmd: dp=7 value=0 descMap.data = [00, 93, 07, 01, 00, 01, 00]
dev:2902023-08-23 16:09:51.801traceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=1 dp=7 fncmd=0 fncmd_len=1 (index=0)
dev:2902023-08-23 16:09:51.790debugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DA1F 01 00 0000 02 01 00930701000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DA1F, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 93, 07, 01, 00, 01, 00]]
dev:2902023-08-23 16:09:51.722infoTuya Temperature Humidity Illuminance LCD Display with a Clock temperature is 0.0 °C
dev:2902023-08-23 16:09:51.713traceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=1 dp=1 fncmd=0 fncmd_len=1 (index=0)
dev:2902023-08-23 16:09:51.682debugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DA1F 01 00 0000 02 01 00920101000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DA1F, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 92, 01, 01, 00, 01, 00]]
dev:2902023-08-23 16:09:47.844traceTuya Temperature Humidity Illuminance LCD Display with a Clock sendZigbeeCommands(cmd=[])
dev:2902023-08-23 16:09:47.840infoTuya Temperature Humidity Illuminance LCD Display with a Clock Debug logging will be turned off after 24 hours
dev:2902023-08-23 16:09:47.807infoTuya Temperature Humidity Illuminance LCD Display with a Clock Debug logging is true; Description text logging is true
dev:2902023-08-23 16:09:47.804infoTuya Temperature Humidity Illuminance LCD Display with a Clock Updating null (Tuya Temperature Humidity Illuminance LCD Display with a Clock) model TS0601 manufacturer _TZE200_e3oitdyu modelGroupPreference = Auto detect (UNKNOWN)
dev:2902023-08-23 16:09:47.060infoTuya Temperature Humidity Illuminance LCD Display with a Clock Received Write Attribute Response for cluster:0000 , data=[00] (Status: Success)
dev:2902023-08-23 16:09:47.050debugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 0000 01 01 0040 00 DA1F 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DA1F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:2902023-08-23 16:09:46.884debugTuya Temperature Humidity Illuminance LCD Display with a Clock NOT PARSED : [raw:DA1F01000068040042105F545A453230305F65336F69746479750000002003010000204405000042065453303630310700003001FEFF003000, dni:DA1F, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE200_e3oitdyu, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:44, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:2902023-08-23 16:09:46.871debugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:DA1F01000068040042105F545A453230305F65336F69746479750000002003010000204405000042065453303630310700003001FEFF003000, dni:DA1F, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE200_e3oitdyu, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:44, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:2902023-08-23 16:09:46.707traceTuya Temperature Humidity Illuminance LCD Display with a Clock sendZigbeeCommands(cmd=[he raw 0xDA1F 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0xDA1F 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200, delay 299])
dev:2902023-08-23 16:09:46.701infoTuya Temperature Humidity Illuminance LCD Display with a Clock initializeDevice...
dev:2902023-08-23 16:09:46.686infoTuya Temperature Humidity Illuminance LCD Display with a Clock configure()..
dev:2902023-08-23 16:09:46.562infoTuya Temperature Humidity Illuminance LCD Display with a Clock Statistics were reset. Press F5 to refresh the device page
dev:2902023-08-23 16:09:46.552infoTuya Temperature Humidity Illuminance LCD Display with a Clock InitializeVars()... fullInit = true
dev:2902023-08-23 16:09:46.539infoTuya Temperature Humidity Illuminance LCD Display with a Clock installed()...
