Driver for "TS0601 Dimmers" 1 and 2 Gang Tuya Compatible Devices
I installed your last driver and tried again.
Unpair, pair again. The device is detected as temperature sensor again.
Reset all with driver "device" and put your driver.
But I still have the same problem and errors in logs:
dev:2892023-08-23 12:22:40.111infoscheduling health check every 10 minutes
dev:2892023-08-23 12:22:40.107infoInitializeVars( fullInit = false )...
dev:2892023-08-23 12:21:06.384errorjava.lang.NullPointerException: Cannot set property 'cmdTime' on null object on line 810 (method toggle)
dev:2892023-08-23 12:21:01.338errorjava.lang.NullPointerException: Cannot set property 'cmdTime' on null object on line 810 (method off)
dev:2892023-08-23 12:20:59.061errorjava.lang.NullPointerException: Cannot set property 'cmdTime' on null object on line 810 (method on)
dev:2892023-08-23 12:20:36.279errorgroovy.lang.GroovyRuntimeException: Ambiguous method overloading for method com.hubitat.app.DeviceWrapper#updateSetting.
Cannot resolve which method to invoke for [class java.lang.String, null] due to overlapping prototypes between:
[class java.lang.String, interface java.util.List]
[class java.lang.String, interface java.util.Map] on line 684 (method configure)
dev:2892023-08-23 12:20:36.064infoscheduling health check every 10 minutes
dev:2892023-08-23 12:20:36.001infoInitializeVars( fullInit = false )...
dev:2892023-08-23 12:19:51.941errorjava.lang.NullPointerException: Cannot invoke method getDeviceNetworkId() on null object on line 475 (method toggle)
dev:2892023-08-23 12:19:48.954errorjava.lang.NullPointerException: Cannot invoke method multiply() on null object on line 532 (method setLevel)
dev:2892023-08-23 12:19:47.223errorjava.lang.NullPointerException: Cannot invoke method multiply() on null object on line 532 (method setLevel)
dev:2892023-08-23 12:19:42.673errorjava.lang.NullPointerException: Cannot invoke method getDeviceNetworkId() on null object on line 475 (method off)
dev:2892023-08-23 12:19:40.303errorjava.lang.NullPointerException: Cannot invoke method getDeviceNetworkId() on null object on line 475 (method on)
dev:2892023-08-23 12:19:22.871errorjava.lang.NullPointerException: Cannot get property 'numEps' on null object on line 191 (method configure)
dev:2892023-08-23 12:18:50.044infostate.configState was removed...
dev:2892023-08-23 12:18:50.042infostate.notPresentCounter was removed...
dev:2892023-08-23 12:18:50.041infostate.driverVersion was removed...
dev:2892023-08-23 12:18:50.040infostate.stats was removed...
dev:2892023-08-23 12:18:50.039infostate.lastRx was removed...
dev:2892023-08-23 12:18:50.038infostate.modelGroup was removed...
dev:2892023-08-23 12:18:50.037infostate.lastTx was removed...
dev:2892023-08-23 12:18:49.248infoany scheduled jobs were deleted...
dev:2892023-08-23 12:17:51.303debugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DA1F 01 00 0000 11 01 002682, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DA1F, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:11, direction:01, data:[00, 26, 82]]
dev:2892023-08-23 12:17:35.361debugTuya Temperature Humidity Illuminance LCD Display with a Clock NOT PARSED : [raw:DA1F01000026DFFF420FE0CB772C13CBA7782C12CCA7782C12, dni:DA1F, endpoint:01, cluster:0000, size:26, attrId:FFDF, encoding:42, command:0A, value:àËw,˧x,̧x,, clusterInt:0, attrInt:65503]
dev:2892023-08-23 12:17:35.323debugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:DA1F01000026DFFF420FE0CB772C13CBA7782C12CCA7782C12, dni:DA1F, endpoint:01, cluster:0000, size:26, attrId:FFDF, encoding:42, command:0A, value:àËw,˧x,̧x,, clusterInt:0, attrInt:65503]
dev:2892023-08-23 12:17:35.048debugTuya Temperature Humidity Illuminance LCD Display with a Clock Tuya check-in message (attribute 0001 reported: 44)
dev:2892023-08-23 12:17:35.041debugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:DA1F0100001801002044E2FF201FE4FF2000, dni:DA1F, endpoint:01, cluster:0000, size:18, attrId:0001, encoding:20, command:0A, value:44, clusterInt:0, attrInt:1, additionalAttrs:[[value:1F, encoding:20, attrId:FFE2, consumedBytes:4, attrInt:65506], [value:00, encoding:20, attrId:FFE4, consumedBytes:4, attrInt:65508]]]
dev:2892023-08-23 12:17:31.488debugTuya Temperature Humidity Illuminance LCD Display with a Clock Tuya cluster confirmation for command 0x24 response 0x00 data = [24, 00]
dev:2892023-08-23 12:17:31.483debugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DA1F 00 00 0000 0B 01 2400, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DA1F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[24, 00]]
dev:2892023-08-23 12:17:31.371debugTuya Temperature Humidity Illuminance LCD Display with a Clock sending time data : [he cmd 0xDA1F 0x01 0xEF00 0x24 {000864E5EACB64E5F8DB}, delay 2000]
dev:2892023-08-23 12:17:31.369traceTuya Temperature Humidity Illuminance LCD Display with a Clock now is: 1692789451369
dev:2892023-08-23 12:17:31.355debugTuya Temperature Humidity Illuminance LCD Display with a Clock time synchronization request from device, descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DA1F 01 00 0000 24 01 0024, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DA1F, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:24, direction:01, data:[00, 24]]
dev:2892023-08-23 12:17:31.349debugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DA1F 01 00 0000 24 01 0024, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DA1F, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:24, direction:01, data:[00, 24]]
dev:2892023-08-23 12:17:28.325warnTuya Temperature Humidity Illuminance LCD Display with a Clock warning: temperature alarm upper limit reported by the device (0.0 C) differs from the preference setting (39.0 C)
dev:2892023-08-23 12:17:28.321traceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=4 dp=10 fncmd=0 fncmd_len=1 (index=0)
dev:2892023-08-23 12:17:28.314debugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DA1F 01 00 0000 02 01 007A0A04000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DA1F, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 7A, 0A, 04, 00, 01, 00]]
dev:2892023-08-23 12:17:28.226infoTuya Temperature Humidity Illuminance LCD Display with a Clock battery is 0 %
dev:2892023-08-23 12:17:28.220debugTuya Temperature Humidity Illuminance LCD Display with a Clock getBatteryPercentageResult: rawValue = 0 -> 0%
dev:2892023-08-23 12:17:28.211traceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=4 dp=4 fncmd=0 fncmd_len=1 (index=0)
dev:2892023-08-23 12:17:28.204debugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DA1F 01 00 0000 02 01 00790404000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DA1F, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 79, 04, 04, 00, 01, 00]]
dev:2892023-08-23 12:17:28.106infoTuya Temperature Humidity Illuminance LCD Display with a Clock Temperature scale reported by device is: Celsius
dev:2892023-08-23 12:17:28.104traceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=2 dp=9 fncmd=0 fncmd_len=4 (index=0)
dev:2892023-08-23 12:17:28.097debugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DA1F 01 00 0000 02 01 00780902000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DA1F, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 78, 09, 02, 00, 04, 00, 00, 00, 00]]
dev:2892023-08-23 12:17:28.004infoTuya Temperature Humidity Illuminance LCD Display with a Clock illuminance is 0 Lux
dev:2892023-08-23 12:17:27.995traceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=2 dp=3 fncmd=0 fncmd_len=4 (index=0)
dev:2892023-08-23 12:17:27.988debugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DA1F 01 00 0000 02 01 00770302000400000000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DA1F, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 77, 03, 02, 00, 04, 00, 00, 00, 00]]
dev:2892023-08-23 12:17:27.451warnTuya Temperature Humidity Illuminance LCD Display with a Clock NOT PROCESSED Tuya cmd: dp=8 value=125 descMap.data = [00, 74, 08, 02, 00, 04, 00, 00, 00, 7D]
dev:2892023-08-23 12:17:27.449traceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=2 dp=8 fncmd=125 fncmd_len=4 (index=0)
dev:2892023-08-23 12:17:27.440debugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DA1F 01 00 0000 02 01 0074080200040000007D, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DA1F, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 74, 08, 02, 00, 04, 00, 00, 00, 7D]]
dev:2892023-08-23 12:17:27.149warnTuya Temperature Humidity Illuminance LCD Display with a Clock ignored invalid humidity 131 (131.0)
dev:2892023-08-23 12:17:27.140traceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=2 dp=2 fncmd=131 fncmd_len=4 (index=0)
dev:2892023-08-23 12:17:27.132debugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DA1F 01 00 0000 02 01 00730202000400000083, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DA1F, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 73, 02, 02, 00, 04, 00, 00, 00, 83]]
dev:2892023-08-23 12:17:27.020warnTuya Temperature Humidity Illuminance LCD Display with a Clock NOT PROCESSED Tuya cmd: dp=7 value=0 descMap.data = [00, 72, 07, 01, 00, 01, 00]
dev:2892023-08-23 12:17:27.017traceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=1 dp=7 fncmd=0 fncmd_len=1 (index=0)
dev:2892023-08-23 12:17:27.010debugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DA1F 01 00 0000 02 01 00720701000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DA1F, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 72, 07, 01, 00, 01, 00]]
dev:2892023-08-23 12:17:26.938infoTuya Temperature Humidity Illuminance LCD Display with a Clock temperature is 0.0 °C
dev:2892023-08-23 12:17:26.930traceTuya Temperature Humidity Illuminance LCD Display with a Clock dp_id=1 dp=1 fncmd=0 fncmd_len=1 (index=0)
dev:2892023-08-23 12:17:26.901debugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 EF00 01 01 0040 00 DA1F 01 00 0000 02 01 00710101000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DA1F, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 71, 01, 01, 00, 01, 00]]
dev:2892023-08-23 12:17:23.212traceTuya Temperature Humidity Illuminance LCD Display with a Clock sendZigbeeCommands(cmd=[])
dev:2892023-08-23 12:17:23.209infoTuya Temperature Humidity Illuminance LCD Display with a Clock Debug logging will be turned off after 24 hours
dev:2892023-08-23 12:17:23.170infoTuya Temperature Humidity Illuminance LCD Display with a Clock Debug logging is true; Description text logging is true
dev:2892023-08-23 12:17:23.167infoTuya Temperature Humidity Illuminance LCD Display with a Clock Updating null (Tuya Temperature Humidity Illuminance LCD Display with a Clock) model TS0601 manufacturer _TZE200_e3oitdyu modelGroupPreference = Auto detect (UNKNOWN)
dev:2892023-08-23 12:17:22.482infoTuya Temperature Humidity Illuminance LCD Display with a Clock Received Write Attribute Response for cluster:0000 , data=[00] (Status: Success)
dev:2892023-08-23 12:17:22.472debugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:catchall: 0104 0000 01 01 0040 00 DA1F 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:DA1F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:2892023-08-23 12:17:22.300debugTuya Temperature Humidity Illuminance LCD Display with a Clock NOT PARSED : [raw:DA1F01000068040042105F545A453230305F65336F69746479750000002003010000204405000042065453303630310700003001FEFF003000, dni:DA1F, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE200_e3oitdyu, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:44, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:2892023-08-23 12:17:22.289debugTuya Temperature Humidity Illuminance LCD Display with a Clock parse() descMap = [raw:DA1F01000068040042105F545A453230305F65336F69746479750000002003010000204405000042065453303630310700003001FEFF003000, dni:DA1F, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE200_e3oitdyu, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:44, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:2892023-08-23 12:17:22.091traceTuya Temperature Humidity Illuminance LCD Display with a Clock sendZigbeeCommands(cmd=[he raw 0xDA1F 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0xDA1F 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200, delay 299])
dev:2892023-08-23 12:17:22.085infoTuya Temperature Humidity Illuminance LCD Display with a Clock initializeDevice...
dev:2892023-08-23 12:17:22.028infoTuya Temperature Humidity Illuminance LCD Display with a Clock configure()..
dev:2892023-08-23 12:17:21.880infoTuya Temperature Humidity Illuminance LCD Display with a Clock Statistics were reset. Press F5 to refresh the device page
dev:2892023-08-23 12:17:21.873infoTuya Temperature Humidity Illuminance LCD Display with a Clock InitializeVars()... fullInit = true
dev:2892023-08-23 12:17:21.857infoTuya Temperature Humidity Illuminance LCD Display with a Clock installed()...
Show more...
