Is there any chance of a driver being developed specifically for the Schlage JFE109 Handle Lock on the C-7 platform? The problem I’m having is that I don’t see a user code when the door is unlocked. I have tried both the Generic Z-Wave Lock and Schlage FE599/BE369 Lock drivers but neither shows a user code in the log file.
Have you tried the be469 driver? (make sure you click configure when you change drivers)
That said the generic z-wave driver should pick up the availability of codes if they’re available.
I am now using the BE469 driver with my JFE109 lock because it allows me to enter user names whereas the generic lock driver did not. However it does not show which user unlocks the door. The activating user name or slot number does not appear to be available. Thank you for the BE469 suggestion.
