I have issues with a new Z-wave device that might be driver related.
Another thread said the "Aeotec Smart Switch 6" driver could be used so I'm trying that.
It doesn't respond reliably to on/off requests (at least as reported by device page) but it reports voltage and current constantly (see below). I'm thinking the device is so busy sending voltage and current info, it doesn't have time (or misses) on/off requests.
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:36:24.427 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump current is 0.000 A
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:36:23.818 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump voltage is 245.947 V
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:36:19.427 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump current is 0.000 A
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:36:18.817 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump voltage is 245.857 V
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:36:14.427 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump current is 0.000 A
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:36:13.818 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump voltage is 245.931 V
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:36:09.427 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump current is 0.000 A
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:36:08.818 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump voltage is 245.917 V
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:36:04.607 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump current is 0.000 A
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:36:03.818 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump voltage is 245.703 V
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:35:59.427 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump current is 0.000 A
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:35:58.818 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump voltage is 245.670 V
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:35:54.427 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump current is 0.000 A
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:35:53.818 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump voltage is 245.551 V
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:35:49.427 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump current is 0.000 A
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:35:48.818 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump voltage is 245.492 V
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:35:44.427 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump current is 0.000 A
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:35:43.818 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump voltage is 245.541 V
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:35:39.426 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump current is 0.000 A
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:35:38.817 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump voltage is 245.575 V
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:35:34.427 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump current is 0.000 A
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:35:33.817 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump voltage is 245.490 V
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:35:29.427 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump current is 0.000 A
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:35:28.818 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump voltage is 245.530 V
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:35:24.426 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump current is 0.000 A
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:35:23.818 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump voltage is 245.609 V
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:35:19.426 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump current is 0.000 A
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:35:18.817 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump voltage is 245.530 V
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:35:14.428 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump current is 0.000 A
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:35:13.818 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump voltage is 245.345 V
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:35:09.432 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump current is 0.000 A
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:35:08.817 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump voltage is 245.440 V
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:35:04.426 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump current is 0.000 A
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:35:03.818 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump voltage is 245.431 V
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:34:59.426 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump current is 0.000 A
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:34:58.817 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump voltage is 245.426 V
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:34:54.426 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump current is 0.000 A
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:34:53.817 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump voltage is 245.524 V
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:34:49.427 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump current is 0.000 A
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:34:48.817 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump voltage is 245.412 V
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:34:44.427 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump current is 0.000 A
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:34:43.817 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump voltage is 245.269 V
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:34:39.426 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump current is 0.000 A
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:34:38.817 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump voltage is 245.306 V
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:34:34.426 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump current is 0.000 A
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:34:33.817 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump voltage is 245.396 V
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:34:29.426 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump current is 0.000 A
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:34:28.817 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump voltage is 245.437 V
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:34:24.426 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump current is 0.000 A
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:34:23.817 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump voltage is 245.507 V
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:34:19.426 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump current is 0.000 A
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:34:18.826 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump voltage is 245.457 V
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:34:14.426 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump current is 0.000 A
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:34:13.817 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump voltage is 245.364 V
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:34:09.425 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump current is 0.000 A
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:34:08.816 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump voltage is 245.396 V
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:34:04.425 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump current is 0.000 A
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:34:03.817 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump voltage is 245.355 V
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:33:59.425 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump current is 0.000 A
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:33:58.817 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump voltage is 245.232 V
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:33:54.425 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump current is 0.000 A
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:33:53.817 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump voltage is 245.048 V
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:33:49.425 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump current is 0.000 A
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:33:48.817 pm [info](http://192.168.0.213/device/edit/469)Irrigation Boost Pump voltage is 245.160
There are preferences for power reporting interval and/or setting thresholds for the change required before status is sent. But, changing those doesn't seem to have an effect. And, after trying to change them, I get messages in the log saying I have to save the device again:
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:31:52.502 pm [warn](http://192.168.0.213/device/edit/469)There are 4 pending changes, please click the Save button again.
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:31:50.532 pm [debug](http://192.168.0.213/device/edit/469)CHANGING Power Reporting Interval(#111) from 5 to 3600
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:31:50.528 pm [debug](http://192.168.0.213/device/edit/469)CHANGING Power Reporting Thresholds(#90) from 0 to 1
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:31:50.524 pm [debug](http://192.168.0.213/device/edit/469)CHANGING LED Night Light Color(#83) from null to 1
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:31:50.520 pm [debug](http://192.168.0.213/device/edit/469)CHANGING LED Mode(#81) from null to 0
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:31:48.446 pm [warn](http://192.168.0.213/device/edit/469)description logging is: true
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:31:48.444 pm [warn](http://192.168.0.213/device/edit/469)debug logging is: true
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:31:48.442 pm [info](http://192.168.0.213/device/edit/469)updated...
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:31:44.806 pm [warn](http://192.168.0.213/device/edit/469)There are 4 pending changes, please click the Save button again.
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:31:42.840 pm [debug](http://192.168.0.213/device/edit/469)CHANGING Power Reporting Interval(#111) from 5 to 3600
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:31:42.836 pm [debug](http://192.168.0.213/device/edit/469)CHANGING Power Reporting Thresholds(#90) from 0 to 1
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:31:42.833 pm [debug](http://192.168.0.213/device/edit/469)CHANGING LED Night Light Color(#83) from null to 1
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:31:42.829 pm [debug](http://192.168.0.213/device/edit/469)CHANGING LED Mode(#81) from null to 0
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:31:40.755 pm [warn](http://192.168.0.213/device/edit/469)description logging is: true
[dev:469](http://192.168.0.213/logs#dev469)2022-06-29 02:31:40.752 pm [warn](http://192.168.0.213/device/edit/469)debug logging is: true
Does anyone know if the Gen6 driver actually works for a Gen5 device? There is also an "Aeotec Smart Energy Switch" driver (versus Smart Switch 6 and Smart Switch 7 US).
