Maybe try this one. I use this in conjunction with the Generic Child driver.
// 12.18.2018: Added double click capability
// Added temperature measurement capability
// Buttons can be separated from switch (buttons and switches work just fine, but they work independently)
metadata {
definition (name: "Aqara 1/2 Wall Sw, no neutral)", namespace: "guyee", author: "P�ter Guly�s") {
capability "Configuration"
capability "Refresh"
capability "PushableButton"
capability "HoldableButton"
capability "ReleasableButton"
capability "DoubleTapableButton"
capability "Temperature Measurement"
command "childOn"
command "childOff"
command "childRefresh"
command "recreateChildDevices"
command "deleteChildren"
// QBKG04LM: one button, no neutral required
// Disconnect button from relay: write uint8 (0x20) value (connected: 0x12, disconnected: 0xFE) to attribute 0xFF22 of endpoint 0x01, cluster 0x0000
fingerprint profileId: "0104", inClusters: "0000,0003,0001,0002,0019,000A", outClusters: "0000,000A,0019", manufacturer: "LUMI", model: "lumi.ctrl_neutral1", deviceJoinName: "Aqara Wall switch"
// QBKG03LM: two buttons, no neutral required
// Disconnect left button from relay: write uint8 (0x20) value (connected: 0x12, disconnected: 0xFE) to attribute 0xFF22 of endpoint 0x01, cluster 0x0000
// Disconnect right button from relay: write uint8 (0x20) value (connected: 0x22, disconnected: 0xFE) to attribute 0xFF22 of endpoint 0x01, cluster 0x0000
fingerprint profileId: "0104", inClusters: "0000,0003,0001,0002,0019,000A", outClusters: "0000,000A,0019", manufacturer: "LUMI", model: "lumi.ctrl_neutral2", deviceJoinName: "Aqara Wall switch"
preferences {
input name: "numButtons", type: "enum", description: "", title: "Number of buttons", options: [[1:"1"],[2:"2"]], defaultValue: 1
input name: "logEnable", type: "bool", title: "Enable debug logging", defaultValue: true
input name: "txtEnable", type: "bool", title: "Enable descriptionText logging", defaultValue: true
input name: "leftButtonDisconnect", type: "bool", title: "Disconnect left button from switch", defaultValue: false
input name: "rightButtonDisconnect", type: "bool", title: "Disconnect right button from switch (double button devices)", defaultValue: false
def logsOff(){
log.warn "debug logging disabled..."
// device.updateSetting("logEnable",[value:"false",type:"bool"])
def childRefresh(String deviceId)
def endpointId = endpointNumber(deviceId);
return [
"he rattr 0x${device.deviceNetworkId} ${endpointId} 0x0006 0 {}","delay 200", //light state
def refresh() {
def cmds = []
def children = getChildDevices()
children?.each{
cmds += childRefresh(it.deviceNetworkId)
return cmds
if (txtEnable) {
log.debug description
if (description.startsWith("catchall"))
return
def events = []
def cluster = Integer.parseInt(description.split(",").find {it.split(":")[0].trim() == "cluster"}?.split(":")[1].trim(), 16)
def endpoint = Integer.parseInt(description.split(",").find {it.split(":")[0].trim() == "endpoint"}?.split(":")[1].trim(), 16)
def attrId = Integer.parseInt(description.split(",").find {it.split(":")[0].trim() == "attrId"}?.split(":")[1].trim(), 16)
def valueHex = description.split(",").find {it.split(":")[0].trim() == "value"}?.split(":")[1].trim()
if (cluster == 0x0006) { // on/off
if (isSwitchEP(endpoint)) {
if (attrId == 0x0000) {
def childDevice = getChildDevice("${device.zigbeeId}-${endpoint}")
def switchState
if (Integer.parseInt(valueHex[0..1], 16))
switchState = "on"
else
switchState = "off"
childDevice.sendEvent(name:"switch", value:switchState, descriptionText:"Switch #${EPtoIndex(endpoint)} has been turned $switchState")
} else {
log.warn("Unknown attribute $attrId for endpoint $endpoint")
} else if (isButtonEP(endpoint)) {
def messageMap = [
"00": "held",
"0000001001": "single-clicked",
"01": "released",
"02": "double-clicked"
def eventTypeMap = [
"00": "held",
"0000001001": "pushed",
"01": "released",
"02": "doubleTapped"
events += [
value: EPtoIndex(endpoint),
isStateChange: true,
descriptionText: "Button was ${messageMap[valueHex]}"
} else {
} else {
log.warn("Unknown endpoint $endpoint")
} else if (cluster == 0x0000) {
def descMap = zigbee.parseDescriptionAsMap(description)
def prefixLen = 4 + 2 + 4 // dni + endpoint + cluster
def msgLen = Integer.parseInt(descMap.raw[prefixLen..(prefixLen + 1)], 16)
events += parseXiaomiReport(descMap.raw[(prefixLen + 2)..(descMap.raw.length() - 1)])
} else {
log.info("Unknown message: $description")
return events
private int toBigEndian(String hex) {
int ret = 0;
String hexBigEndian = "";
if (hex.length() % 2 != 0) return ret;
for (int i = hex.length() - 2; i >= 0; i -= 2) {
hexBigEndian += hex.substring(i, i + 2);
ret = Integer.parseInt(hexBigEndian, 16);
return ret;
private parseXiaomiReport(description) {
displayDebugLog("Xiaomi parse string = ${description}")
def msgPos = 0
def msgLength = description.size()
def modelId = null;
def manufacturerSpecificValues = null;
while (msgPos < msgLength) {
def attrId = toBigEndian(description[msgPos++..(msgPos+=3)-1])
def dataType = Integer.parseInt(description[msgPos++..msgPos++], 16)
def dataLen = DataType.getLength(dataType)
if (dataLen == null || dataLen == -1) { // Probably variable length
switch (dataType) {
case DataType.STRING_OCTET:
case DataType.STRING_CHAR:
dataLen = Integer.parseInt(description[msgPos++..msgPos++], 16)
break;
case DataType.STRING_LONG_OCTET:
case DataType.STRING_LONG_CHAR:
dataLen = toBigEndian(description[msgPos++..(msgPos+=3)-1])
break;
default:
log.error("Unsupported data type in Xiaomi Report msg: attrID = 0x${Integer.toHexString(attrId)}, type = 0x${Integer.toHexString(dataType)}")
return
if (dataLen * 2 > msgLength - msgPos) { // Yes, it happens with lumi.sensor_86sw2 (WXKG02LM)
log.error("WTF Xiaomi, packet length received from you (${dataLen} bytes) is greater than the length of remaining data (${(msgLength - msgPos) / 2} bytes)!")
dataLen = (msgLength - msgPos) / 2
def dataPayload
if (dataLen != 0)
dataPayload = description[msgPos++..(msgPos+=(dataLen * 2) - 1)-1]
switch (attrId) {
case 0xFF01:
manufacturerSpecificValues = parseXiaomiReport_FF01(dataPayload)
displayDebugLog(manufacturerSpecificValues);
break;
case 0x0005:
modelId = parseXiaomiReport_0005(dataPayload)
break;
default:
log.warn("Unsupported attribute in Xiaomi Report msg: attrID = 0x${Integer.toHexString(attrId)}, type = 0x${Integer.toHexString(dataType)}, length = ${dataLen} bytes, payload = ${dataPayload}")
def events = []
/* Non battery-powered devices
if (manufacturerSpecificValues?.containsKey("BatteryPct")) {
events += [
value: manufacturerSpecificValues["BatteryPct"],
unit: "%",
descriptionText: "Battery level is ${manufacturerSpecificValues["BatteryPct"]}% (${manufacturerSpecificValues["BatteryVolts"]} Volts)"
if (manufacturerSpecificValues?.containsKey("Temperature")) {
events += [
value: manufacturerSpecificValues["Temperature"],
unit: "°C",
descriptionText: "Temperature is ${manufacturerSpecificValues["Temperature"]}°C"
if (manufacturerSpecificValues?.containsKey("Power")) {
events += [
value: manufacturerSpecificValues["Power"],
unit: "W",
descriptionText: "Actual power consumption is ${manufacturerSpecificValues["Power"]}W"
if (manufacturerSpecificValues?.containsKey("Energy")) {
events += [
value: manufacturerSpecificValues["Energy"],
unit: "kWh",
descriptionText: "Power consumption so far is ${manufacturerSpecificValues["Energy"]}kWh"
if (manufacturerSpecificValues?.containsKey("RouterID")) {
state.routerID = manufacturerSpecificValues["RouterID"].toUpperCase()
return events
private parseXiaomiReport_FF01(payload) {
displayDebugLog("Xiaomi parse FF01 string = ${payload}")
def values = [ : ]
def msgPos = 0
def msgLength = payload.size()
def dataTag = Integer.parseInt(payload[msgPos++..msgPos++], 16)
def dataType = Integer.parseInt(payload[msgPos++..msgPos++], 16)
switch (dataType) {
dataLen = Integer.parseInt(payload[msgPos++..msgPos++], 16)
break;
dataLen = toBigEndian(payload[msgPos++..(msgPos+=3)-1])
break;
default:
return
def dataPayload
if (dataLen != 0)
dataPayload = payload[msgPos++..(msgPos+=(dataLen * 2) - 1)-1]
switch (dataTag) {
case 0x01: // Battery
def rawVolts = toBigEndian(dataPayload) / 1000
def minVolts = voltsmin ? voltsmin : 2.5
def maxVolts = voltsmax ? voltsmax : 3.0
def pct = (rawVolts - minVolts) / (maxVolts - minVolts)
def roundedPct = Math.min(100, Math.round(pct * 100))
values += [ BatteryPct : roundedPct ]
values += [ BatteryVolts : rawVolts ]
break;
case 0x03: // Temperature
values += [ Temperature : Integer.parseInt(dataPayload, 16, ) -3] // Just a guess :)
break;
case 0x05: // RSSI
values += [ RSSI : (toBigEndian(dataPayload) / 10) - 90 ]
break;
case 0x06: // LQI
values += [ LQI : 255 - toBigEndian(dataPayload) ]
break;
case 0x0A: // router
values += [ RouterID : Integer.toHexString(toBigEndian(dataPayload)) ]
break;
case 0x64: // switch 1 state
values += [ Switch1State : toBigEndian(dataPayload) ]
break;
case 0x65: // switch 2 state
values += [ Switch2State : toBigEndian(dataPayload) ]
break;
case 0x95: // energy
long theValue = Long.parseLong(toBigEndianHexString(dataPayload), 16)
float floatValue = Float.intBitsToFloat(theValue.intValue());
values += [ Energy : floatValue ]
break;
case 0x98: // power
values += [ Power : floatValue ]
break;
default:
displayDebugLog("Unsupported tag in Xiaomi Report msg: dataTag = 0x${Integer.toHexString(dataTag)}, type = 0x${Integer.toHexString(dataType)}, length = ${dataLen} bytes, payload = ${dataPayload}")
return values;
private parseXiaomiReport_0005(payload) {
displayDebugLog("Xiaomi parse 0005 string = ${payload}")
return new String(payload.decodeHex())
def childOn(String deviceId) {
def cmd = [
"he cmd 0x${device.deviceNetworkId} ${endpointId} 0x0006 1 {}",
return cmd
def childOff(String deviceId) {
def cmd = [
"he cmd 0x${device.deviceNetworkId} ${endpointId} 0x0006 0 {}",
return cmd
def configure() {
log.warn "configure..."
runIn(1800,logsOff)
def cmds = []
children?.each{
def endpointId = endpointNumber(it.deviceNetworkId)
cmds += [
//bindings
"zdo bind 0x${device.deviceNetworkId} ${endpointId} 1 0x0006 {${device.zigbeeId}} {}", "delay 200",
//reporting
"he cr 0x${device.deviceNetworkId} ${endpointId} 0x0006 0 0x10 0 0x3600 {}","delay 200",
cmds += zigbee.writeAttribute(0x0000, 0xFF22, DataType.UINT8, leftButtonDisconnect ? 0xFE : 0x12, [mfgCode: "0x115F"])
cmds += zigbee.writeAttribute(0x0000, 0xFF23, DataType.UINT8, rightButtonDisconnect ? 0xFE : 0x22, [mfgCode: "0x115F"])
cmds += refresh()
sendEvent(name:"numberOfButtons", value: numButtons)
return cmds
def installed() {
createChildDevices()
configure()
def updated() {
log.info "updated..."
log.warn "debug logging is: ${logEnable == true}"
log.warn "description logging is: ${txtEnable == true}"
if (logEnable) runIn(1800,logsOff)
if (!childDevices) {
else if (device.label != state.oldLabel) {
childDevices.each {
def newLabel = "$device.displayName (EP${endpointNumber(it.deviceNetworkId)})"
it.setLabel(newLabel)
state.oldLabel = device.label
configure()
def recreateChildDevices() {
log.debug "recreateChildDevices"
deleteChildren()
def deleteChildren() {
log.debug "deleteChildren"
children.each {child->
deleteChildDevice(child.deviceNetworkId)
private void createChildDevices() {
log.debug "createChildDevices"
for (i in 1..numButtons.toInteger()) {
def switchEPId = indexToSwitchEP(i)
addChildDevice("guyee", "Generic Child Switch", "$device.zigbeeId-$switchEPId", [name: "EP$switchEPId", label: "$device.displayName $switchEPId", isComponent: false])
def intTo16bitUnsignedHex(value) {
def hexStr = zigbee.convertToHexString(value.toInteger(),4)
return new String(hexStr.substring(2, 4) + hexStr.substring(0, 2))
def intTo8bitUnsignedHex(value) {
return zigbee.convertToHexString(value.toInteger(), 2)
private endpointNumber(String deviceId) {
return deviceId.split("-")[-1] as Integer
private int indexToSwitchEP(int index) {
return 1 + index
private int indexToButtonEP(int index) {
return 3 + index
private int buttonToSwitchEP(int EP) {
return EP - 2
private int switchToButtonEP(int EP) {
return EP + 2
private boolean isSwitchEP(int EP) {
return (2..3).contains(EP)
private boolean isButtonEP(int EP) {
return (4..5).contains(EP)
private int EPtoIndex(int EP)
return (EP % 2) + 1
private def displayDebugLog(message) {
if (logEnable) log.debug "${device.displayName}: ${message}"
