Hello friends I just received the double switch from aqara without neutral QBKG03LM, I have linked it to the first one but it does not work for me when I enter device, no button, could you help me?
Is there no manual with it?
I can't find anything, how to make them work.
Model | QBKG03LM |
Vendor | Xiaomi |
Description | Aqara double key wired wall switch without neutral wire. Doesn't work as a router and doesn't support power meter |
Exposes | switch (state), temperature, action, operation_mode, linkquality |
Press and hold the button on the device for +- 10 seconds (until the blue light starts blinking and stops blinking), release and wait.
What do you see in the 'Data' section.
I have it linked, but I don't know how to configure the buttons
Its paired? What driver is it using?
Do you have the 'Generic Child Switch' driver installed?
metadata {
definition (name: "Generic Child Switch", namespace: "guyee", author: "P�ter Guly�s") {
capability "Refresh"
capability "Actuator"
capability "Switch"
capability "Light"
def refresh() {
parent.childRefresh(device.deviceNetworkId)
void on() {
log.debug "$device on"
parent.childOn(device.deviceNetworkId)
void off() {
log.debug "$device off"
parent.childOff(device.deviceNetworkId)
Nooo!! do you have to install it ????
OK. Install the Generic Child driver.
I see you have rules already so DO NOT delete.
Try pushing the create child devices and see if it installs them.
where is that option
Sorry Recreate child devices.
I just installed the driver, I go to my device, I give recreatechillddecive and it does nothing to me
Maybe try
Delete children then
Hang on.
What is the name of your driver.
I'm using 'Aqara 1/2 wall sw, no neutral'.
From the screenshot above it is different to yours.
Comeonnn my Friends!!
