Door open repeating notice
Your speak is outside the repeat, so that will only happen once. I'd take a look at this thread for several repeated-notification rule examples you could use to based yours on:
That being said, is there a reason you want to use Rule Machine for this? Learning RM is fine, but the built-in Notifications app can handle this scenario with less work...something like:
