Absolutely awesome job.
I can confirm the fix on version 2.2.9.130 works fully on my Traefik V2 reverse proxy with no config changes and with out the need for whilelists.
Thanks so much!
Thanks so much!
Is this going to be the new norm, where all ip address not on the local network -- and only /24 or longer at that -- need to be whitelisted via the allowSubnets endpoint?
Or is there any plan to hook up an opt-out of this feature in Settings ?
We found enough hubs exposed to the world with no authentication or encryption to make it a permanent, no-disable feature. As above posts suggest, there are workarounds, and they tend to come with some built in security features - use them. Anything that provides SSL based transportation layer and authentication should be good enough.
So i just want to be clear, are we saying that Hubitat has hardened the web interface and believes the only missing piece was TLS?
To be a bit more specific, i deal with PCI Compliance and i have received requests from auditors to do various tasks to harden the servers by preventing certain injection, and other system identify characteristics from being allowed to prevent http application vulnerabilities? Are those steps being taken on the Hubitat UI to prevent that kind of activity.
Using something like a reverse proxy will enable certain security features, but doesn't naturally protect against web application vulnerabilities as i understand it.
We do not think that a hub should be directly accessible over the internet under any circumstances. It is not designed for that. And we do not think a reverse proxy is enough by itself, there should be additional security on top of it. Hub firmware changes discussed above merely make sure that a proxy can access the hub.
Thanks for the clarification. That is what I expected.
hi @cjattard - Apologies for the necro post here, but I see you're a fellow Traefik user and I've not been able to get dashboards to work behind my proxy address (I just get the constantly spinning blue circle "loading dashboards.")
I'm currently on 2.3.1.129. My network setup is pretty straightforward. No VLANs in use, and I've enabled my main internal subnet using (/hub/allowSubnets?192.168.2.0). I'm only testing the subnet locally and haven't even yet tried to test it via my OpenVPN setup at home.
Everything else in Hubitat seems to work behind the proxy, just not the dashboards page. I've got a couple dozen services working properly with Traefik, so I know Traefik is working as well, just not for hubitat dashboards pages. Do your dashboards still work at https://hubitat.customdomain.com/dashboards? If so, any hints from your traefik config would be appreciated. Thanks!
To answer my own post for future Googlers, @cjattard was nice enough me to PM me his complete traefik config. That helped me confirm that the issue was not my traefik config, but the need to update the hub to serve all requests via https when behind a reverse proxy. If you don't click that option, the dashboard page still serves all assets via http and the browser will block it from loading for security reasons.
I'd not seen this option to force SSL before now. If others need a reference, it is discussed here. Thank you!
