How do I stop the 9pm to 8am rule from dimming back to 25% if the dimmer has been manually set to 100% at the physical dimmer? Thanks in advance!
What kind of dimmers? I know inovelli reds have an ability to set the remote and local control dimmer level. You can create rule that changes the level at that time and resets as needed.
I would have to plan out this exact logic but if you have that ability with your switches that would be best.
Lutron dimmer
Then your best bet might be to have a virtual dimmer that the physical switch adjust the virtual dimmer and use that value to set the dimmer values in the rule
