I have 2 Dome repeaters. How do I know if they are working? I went into the device and status is on but when I tried to turn off nothing happens. Having problem with a zigbee plug. Plug is 30 ft from a C8 hub and will turn on lamp but randomly turns off after the specified time. I have change plug twice so not the plug. Also should Hub Mesh be active in device?
You shouldn't be able to turn a repeater off. Can you tell me what model it is?
FYI, your Dome repeaters will do nothing for your zigbee plug. Those repeaters are z-wave devices.
Dome z-wave repeaters have a built-in controllable LED nightlight.
I was thinking they were z-wave only, that's why I wanted a model. Thanks for confirming my thoughts. Yep, won't work for zigbee. (didn't know about turning off the led)
