@mike.maxwell I just purchased which I assume is the latest version of the dome dmdp1 (door and window sensor pro). It paired fine, but was detected as a "device" so I thought I would post the fingerprint info so you can update the system driver for it.
Manufacturer:021FProduct Name:DeviceModel Number:Unknown Part NumberdeviceTypeId:12
I would expect that this would probably work off the bat just by changing the handler(possible exception being the temperature) . The "Device" handler is just what something gets joined as if the fingerprint isn't entered into a device handler to catch the device on join.
@Rxich I have a few of these and they work great. Distance between magnet and unit can be as much as 3/4" - 1" which is better than most. Fast response. Battery life seems to be good also. That is the best price I have seen for it.
Ya, they are good sensors, I still prefer zigbee devices, but they're probably one of the best z-wave plus sensors I've used especially if you don't have a lot of room for bulky magnets or as @razorwing mentioned, need to position the magnet unusually far from the sensor.
