Is the driver for the Dome Motion Sensor working properly? When I select disable the LED in settings of the device, the LED continues to blink. I've excluded and re-added a couple times. Please assist. Thank you.
I do not have one to test, however after you paired the device and turned off the LED did you try pressing the configure button?
I just tested this on my Zooz ZSE40 Ver 2.0 sensor. When I turn off the LED and save preferences, the LED still flashes on a motion trigger, however if I choose "Configure" then wait for the resync to complete, the LED no longer triggers on motion. Hope this helps. If not someone else with the same motion sensor as you will have to chime in.
I think you'll have to make sure the device is "awake" after you hit Configure, which might involve removing and reinserting the battery and/or pressing a button--I have one of these but would have to consult the manual to be sure. That being said, this is a parameter I haven't tried adjusting, so I can't guarantee there isn't really a problem, but the issue I mentioned is common for battery-powered Z-Wave devices.
Thanks guys. I'll give it a try...
Got it working. It was the button push to wake the device up to upload the updated config.
The configuration will be updated the next time the device wakes up. You can force the device to wake up immediately by pressing the connect button once.
