I have two homes both running habitat. I want to control them both from my iPad. Right now, I am using the old app as well as the new habitat app. Each one is signed in with a different user code. Is this the only way I can do it with two habitats and one iPad?
I don't use the IOS versions of the apps, but I think they would be similar to the Android versions where you can switch between hubs within the app.
Do you switch hubs by signing out and then signing in with a different logon?
Do your two hubs share an admin account?
As @socalbigmike said, you can switch between two hubs in the mobile app, but that assumes the hubs are registered to the same account.
Yes, both of my hubs share the same account.
You don't need to sign out, just switch hubs. I believe it asks if you want to use one the current mobile devices, or add a new one. Use your current device.
In the old app click settings, then Hub. In the new app, from the home page, click the hub name (where it says Local or Cloud,) then "Switch to another Hub."
Each hub is on its own account. I also use Alexa in both houses and it requires me to have an account for each one.
You can make guest (non-admin) accounts on each hub so that there is a common account, so you wonβt have to sign out, just switch hubs.
