The Z-Wave setting on HE has a 'Disable Status' with Enable/Disable. I know that HE shuts down Zigbee on high load, would there be any benefit of shutting off Z-Wave for my HE unit? All my devices are zigbee...
I am not having any problems - so this is really an academic question but I upon reading another recent post about zigbee getting disabled, it made me wonder if I could find ways that might improve things down the road. (I did read that MOD about adding an antennae... whoa.)
If you have no zwave devices then leaving it on/turning it off is purely optional. Guess technically, leaving it on could contribute some small amount of RF interference.
I have two hubs, one running Zigbee, the other ZWave, The radio that is not being used is turned off on each bridge that is nut using that protocol. Main reason is I don't want to accidentally add a device to the wrong hub. Since only the one radio is on each hub, I can't make THAT mistake. I also do it so there is no contention of signals between the hubs, as they are sitting next to each other.
