I have a C4 hub, and prior to August 26 was running 2.5.1.152. On that day I updated to 2.5.1.174. Coincidentally or not, that day communication between my Abode (1st gen hub) and my C4 broke. Any number of reboots of both hub and Abode system have failed to fix the problem. At the time I was using the 2020 drivers written by endorphin_junkie and was unaware of the 2024 drivers written by x86cpu. I updated the driver today,as part of the troubleshooting process, but that also failed to restore communications.
On my.goabode.com, the Hubitat shows as a connected device. On the Hubitat web interface, Device Info page for the Abode device shows with correct info, including the correct mac address and device IP. This implies that a connection is made despite the loss of communications.
The most common events I see in the log since communications failed are:
java.lang.SecurityException: Subscript property 'metaClass' is not allowed from app or driver code on line 451 (method refresh)
java.lang.ArrayIndexOutOfBoundsException: Index 1 out of bounds for length 1
with occaisional of the following:
java.lang.NoClassDefFoundError: Could not initialize class com.hubitat.hub.controller.interfaces.WebSocketInterface on line 383
While attempting to troubleshoot, I had two devices created using both 2020 and 2024 drivers. During that time I also saw the following errors. However, they went away once I disabled one set of drivers:
com.hubitat.hub.executor.helpers.ExecutorHttpResponseException: status code: 403, reason phrase: Forbidden
com.hubitat.hub.executor.helpers.ExecutorHttpResponseException: status code: 429, reason phrase: Too Many Requests
Given the timing this appears to be related to the C4 firmware update, has anybody else had problems with the Abode drivers since updating?
