Did Amazon change the way you can create routines?
You need to install Echo Speaks, The best way to install IMO is to use Hubitat Package Manager.
The Hubitat code install should be straight forward using HPM, getting the Heroku server installed can be a bit tricky. If you are having trouble installing Echo Speaks best to go to that thread and ask questions.
