Edit: Sorted, I did something stupid.... as usual
Hi all.
I have the activity monitor app running to keep me informed when a device stops responding and may need to be re-paired. All was working fine until I went on holiday and turned many plugs off (stop energy usage and reduce risk of anything happening while I can't respond). These included the 2nd HE hub I have and many repeaters. When I got back, I switched everything on again and went round re-pairing many devices which were lost with the lack of connections. This I've done many times before without issues. However, this time, I have 2 Hue sensors that were connected to the 2nd hub and 2 Xiaomi sensors that were attached to the main HE hub (I'm assuming through one of the repeaters as the main hub stayed powered so shouldn't have caused any problems) that re-paired fine and do work, but they are not registering their activity. So my activity monitor shows them as not having checked in for months but they are reporting sensor data. I've tried repairing but still do not check in. Does anyone know a fix? I don't want to go removing them and re-adding if possible as it'll be a pain having to reassign to all the rules.
Alan
