Hi @kkossev,
this is first add page:
Also logging after adding:
2022-11-23 09:52:31.362debugZemismart ZigBee Wall Switch Multi-Gang Zemismart ZigBee Wall Switch Multi-Gang unprocessed EP: 00 cluster: 8005 attrId: null
dev:2712022-11-23 09:52:31.359debugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:catchall: 0000 8005 00 00 0040 00 C222 00 00 0000 00 00 950022C2020102, profileId:0000, clusterId:8005, clusterInt:32773, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:C222, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[95, 00, 22, C2, 02, 01, 02]]
dev:2712022-11-23 09:52:30.906warnZemismart ZigBee Wall Switch Multi-Gang Child device 271-01 not found. Initialise parent device first
dev:2712022-11-23 09:52:30.904debugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:C2220100060A00001000, dni:C222, endpoint:01, cluster:0006, size:0A, attrId:0000, encoding:10, command:01, value:00, clusterInt:6, attrInt:0]
dev:2712022-11-23 09:52:30.695debugZemismart ZigBee Wall Switch Multi-Gang Zemismart ZigBee Wall Switch Multi-Gang unprocessed EP: null cluster: null attrId: FFDF
dev:2712022-11-23 09:52:30.693debugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:C22201000012DFFF4205049B102B12, dni:C222, endpoint:01, cluster:0000, size:12, attrId:FFDF, encoding:42, command:0A, value:+, clusterInt:0, attrInt:65503]
dev:2712022-11-23 09:52:30.122debugZemismart ZigBee Wall Switch Multi-Gang Zemismart ZigBee Wall Switch Multi-Gang unprocessed EP: null cluster: null attrId: 0001
dev:2712022-11-23 09:52:30.119debugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:C2220100001801002050E2FF2037E4FF2000, dni:C222, endpoint:01, cluster:0000, size:18, attrId:0001, encoding:20, command:0A, value:50, clusterInt:0, attrInt:1, additionalAttrs:[[value:37, encoding:20, attrId:FFE2, consumedBytes:4, attrInt:65506], [value:00, encoding:20, attrId:FFE4, consumedBytes:4, attrInt:65508]]]
dev:2712022-11-23 09:52:30.024warnZemismart ZigBee Wall Switch Multi-Gang Child device 271-02 not found. Initialise parent device first
dev:2712022-11-23 09:52:29.997debugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:C2220200061C0000100001402100000240210000, dni:C222, endpoint:02, cluster:0006, size:1C, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:0000, encoding:21, attrId:4001, consumedBytes:5, attrInt:16385], [value:0000, encoding:21, attrId:4002, consumedBytes:5, attrInt:16386]]]
dev:2712022-11-23 09:52:29.432warnZemismart ZigBee Wall Switch Multi-Gang Child device 271-01 not found. Initialise parent device first
dev:2712022-11-23 09:52:29.428debugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:C2220100062C00001000014021000002402100000180300102803002, dni:C222, endpoint:01, cluster:0006, size:2C, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:0000, encoding:21, attrId:4001, consumedBytes:5, attrInt:16385], [value:0000, encoding:21, attrId:4002, consumedBytes:5, attrInt:16386], [value:01, encoding:30, attrId:8001, consumedBytes:4, attrInt:32769], [value:02, encoding:30, attrId:8002, consumedBytes:4, attrInt:32770]]]
dev:2712022-11-23 09:52:28.866debugZemismart ZigBee Wall Switch Multi-Gang Zemismart ZigBee Wall Switch Multi-Gang unprocessed EP: 01 cluster: 0006 attrId: null
dev:2712022-11-23 09:52:28.863debugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:catchall: 0104 0006 01 01 0040 00 C222 00 00 0000 07 01 00000000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:C222, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00, 00, 00, 00]]
dev:2712022-11-23 09:52:27.146debugZemismart ZigBee Wall Switch Multi-Gang Zemismart ZigBee Wall Switch Multi-Gang unprocessed EP: 00 cluster: 8021 attrId: null
dev:2712022-11-23 09:52:27.143debugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:catchall: 0000 8021 00 00 0040 00 C222 00 00 0000 00 00 9D00, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:C222, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[9D, 00]]
dev:2712022-11-23 09:52:26.906warnZemismart ZigBee Wall Switch Multi-Gang Child device 271-02 not found. Initialise parent device first
dev:2712022-11-23 09:52:26.903debugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:C2220200060800001000, dni:C222, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0]
dev:2712022-11-23 09:52:26.683warnZemismart ZigBee Wall Switch Multi-Gang Child device 271-01 not found. Initialise parent device first
dev:2712022-11-23 09:52:26.676debugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:C2220100060800001000, dni:C222, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0]
dev:2712022-11-23 09:52:26.639debugZemismart ZigBee Wall Switch Multi-Gang Zemismart ZigBee Wall Switch Multi-Gang unprocessed EP: null cluster: null attrId: 0004
dev:2712022-11-23 09:52:26.635debugZemismart ZigBee Wall Switch Multi-Gang Parsed: [raw:C22201000068040042105F545A333030305F6539386B7276766B0000002003010000205005000042065453303031320700003003FEFF003000, dni:C222, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZ3000_e98krvvk, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:50, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0012, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:2712022-11-23 09:52:26.628infoZemismart ZigBee Wall Switch Multi-Gang InitializeVars()... fullInit = false
dev:2712022-11-23 09:52:26.627debugZemismart ZigBee Wall Switch Multi-Gang updating the settings from the current driver version null to the new version 0.2.9 2022/09/29 7:47 AM
dev:2712022-11-23 09:52:26.464debugZemismart ZigBee Wall Switch Multi-Gang sendZigbeeCommands received : [he raw 0xC222 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, zdo bind 0xC222 0x01 0x01 6 {A4C138A8AACF7A5B} {}, delay 2000, he cr 0xC222 0x01 6 0 16 0 600 {}, delay 2000, he rattr 0xC222 0x01 6 0 {}, delay 2000]
dev:2712022-11-23 09:52:26.459debugZemismart ZigBee Wall Switch Multi-Gang configure()..
dev:2712022-11-23 09:52:26.452debugZemismart ZigBee Wall Switch Multi-Gang Parent installed
And then l change it to another driver:
dev:2712022-11-23 09:55:50.843debugGang en Voordeur buiten : Skipping discovery message.
dev:2712022-11-23 09:55:50.840traceGang en Voordeur buiten : processMap() : [raw:catchall: 0000 8021 00 00 0040 00 C222 00 00 0000 00 00 B082, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:C222, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[B0, 82]]
dev:2712022-11-23 09:55:50.835traceGang en Voordeur buiten : parse() : catchall: 0000 8021 00 00 0040 00 C222 00 00 0000 00 00 B082
dev:2712022-11-23 09:55:48.768infoGang en Voordeur buiten : Relay Configuration : Successful
dev:2712022-11-23 09:55:48.766traceGang en Voordeur buiten : processMap() : [raw:catchall: 0104 0006 01 01 0040 00 C222 00 00 0000 07 01 00000000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:C222, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00, 00, 00, 00]]
dev:2712022-11-23 09:55:48.762traceGang en Voordeur buiten : parse() : catchall: 0104 0006 01 01 0040 00 C222 00 00 0000 07 01 00000000
dev:2712022-11-23 09:55:47.411debugGang en Voordeur buiten : Received 2 outClusters : 0019,000A
dev:2712022-11-23 09:55:47.410debugGang en Voordeur buiten : Received 5 inClusters : 0003,0004,0005,0006,0000
dev:2712022-11-23 09:55:47.398traceGang en Voordeur buiten : processMap() : [raw:catchall: 0000 8004 00 00 0040 00 C222 00 00 0000 00 00 AE0022C21601040100010105030004000500060000000219000A00, profileId:0000, clusterId:8004, clusterInt:32772, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:C222, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[AE, 00, 22, C2, 16, 01, 04, 01, 00, 01, 01, 05, 03, 00, 04, 00, 05, 00, 06, 00, 00, 00, 02, 19, 00, 0A, 00]]
dev:2712022-11-23 09:55:47.392traceGang en Voordeur buiten : parse() : catchall: 0000 8004 00 00 0040 00 C222 00 00 0000 00 00 AE0022C21601040100010105030004000500060000000219000A00
dev:2712022-11-23 09:55:47.185debugGang en Voordeur buiten : Model : TS0012
dev:2712022-11-23 09:55:47.182traceGang en Voordeur buiten : processMap() : [raw:C2220100001605004206545330303132, dni:C222, endpoint:01, cluster:0000, size:16, attrId:0005, encoding:42, command:01, value:TS0012, clusterInt:0, attrInt:5]
dev:2712022-11-23 09:55:47.177traceGang en Voordeur buiten : parse() : read attr - raw: C2220100001605004206545330303132, dni: C222, endpoint: 01, cluster: 0000, size: 16, attrId: 0005, encoding: 42, command: 01, value: 06545330303132
dev:2712022-11-23 09:55:47.077debugGang en Voordeur buiten : Manufacturer : _TZ3000_e98krvvk
dev:2712022-11-23 09:55:47.074traceGang en Voordeur buiten : processMap() : [raw:C2220100002A040042105F545A333030305F6539386B7276766B, dni:C222, endpoint:01, cluster:0000, size:2A, attrId:0004, encoding:42, command:01, value:_TZ3000_e98krvvk, clusterInt:0, attrInt:4]
dev:2712022-11-23 09:55:47.068traceGang en Voordeur buiten : parse() : read attr - raw: C2220100002A040042105F545A333030305F6539386B7276766B, dni: C222, endpoint: 01, cluster: 0000, size: 2A, attrId: 0004, encoding: 42, command: 01, value: 105F545A333030305F6539386B7276766B
dev:2712022-11-23 09:55:46.959debugGang en Voordeur buiten : Application : 50
dev:2712022-11-23 09:55:46.957traceGang en Voordeur buiten : processMap() : [raw:C2220100000A01002050, dni:C222, endpoint:01, cluster:0000, size:0A, attrId:0001, encoding:20, command:01, value:50, clusterInt:0, attrInt:1]
dev:2712022-11-23 09:55:46.952traceGang en Voordeur buiten : parse() : read attr - raw: C2220100000A01002050, dni: C222, endpoint: 01, cluster: 0000, size: 0A, attrId: 0001, encoding: 20, command: 01, value: 50
dev:2712022-11-23 09:55:46.844debugGang en Voordeur buiten : Skipping discovery message.
dev:2712022-11-23 09:55:46.841traceGang en Voordeur buiten : processMap() : [raw:catchall: 0000 8021 00 00 0040 00 C222 00 00 0000 00 00 AA00, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:C222, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[AA, 00]]
dev:2712022-11-23 09:55:46.837traceGang en Voordeur buiten : parse() : catchall: 0000 8021 00 00 0040 00 C222 00 00 0000 00 00 AA00
dev:2712022-11-23 09:55:13.943warnGang en Voordeur buiten Child device 271-01 not found. Initialise parent device first
dev:2712022-11-23 09:55:13.941debugGang en Voordeur buiten Parsed: [raw:C2220100060A00001000, dni:C222, endpoint:01, cluster:0006, size:0A, attrId:0000, encoding:10, command:01, value:00, clusterInt:6, attrInt:0]
dev:2712022-11-23 09:55:11.823debugGang en Voordeur buiten Gang en Voordeur buiten unprocessed EP: 01 cluster: 0006 attrId: null
dev:2712022-11-23 09:55:11.821debugGang en Voordeur buiten Parsed: [raw:catchall: 0104 0006 01 01 0040 00 C222 00 00 0000 07 01 00000000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:C222, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00, 00, 00, 00]]
dev:2712022-11-23 09:55:11.601warnGang en Voordeur buiten Child device 271-01 not found. Initialise parent device first
dev:2712022-11-23 09:55:11.599debugGang en Voordeur buiten Parsed: [raw:C2220100060A00001000, dni:C222, endpoint:01, cluster:0006, size:0A, attrId:0000, encoding:10, command:01, value:00, clusterInt:6, attrInt:0]
dev:2712022-11-23 09:55:09.988debugGang en Voordeur buiten Gang en Voordeur buiten unprocessed EP: 00 cluster: 8021 attrId: null
dev:2712022-11-23 09:55:09.986debugGang en Voordeur buiten Parsed: [raw:catchall: 0000 8021 00 00 0040 00 C222 00 00 0000 00 00 A600, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:C222, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[A6, 00]]
dev:2712022-11-23 09:55:09.882debugGang en Voordeur buiten Gang en Voordeur buiten unprocessed EP: null cluster: null attrId: 0004
dev:2712022-11-23 09:55:09.878debugGang en Voordeur buiten Parsed: [raw:C22201000068040042105F545A333030305F6539386B7276766B0000002003010000205005000042065453303031320700003003FEFF003000, dni:C222, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZ3000_e98krvvk, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:50, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0012, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:2712022-11-23 09:55:09.771debugGang en Voordeur buiten Gang en Voordeur buiten unprocessed EP: 01 cluster: 0006 attrId: null
dev:2712022-11-23 09:55:09.769debugGang en Voordeur buiten Parsed: [raw:catchall: 0104 0006 01 01 0040 00 C222 00 00 0000 07 01 00000000, profileId:0104, clusterId:0006, clusterInt:6, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:C222, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00, 00, 00, 00]]
dev:2712022-11-23 09:55:09.553debugGang en Voordeur buiten sendZigbeeCommands received : [he raw 0xC222 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, zdo bind 0xC222 0x01 0x01 6 {A4C138A8AACF7A5B} {}, delay 2000, he cr 0xC222 0x01 6 0 16 0 600 {}, delay 2000, he rattr 0xC222 0x01 6 0 {}, delay 2000]
dev:2712022-11-23 09:55:09.546debugGang en Voordeur buiten configure()..
dev:2712022-11-23 09:55:07.594debugGang en Voordeur buiten Gang en Voordeur buiten unprocessed EP: 00 cluster: 8021 attrId: null
dev:2712022-11-23 09:55:07.590debugGang en Voordeur buiten Parsed: [raw:catchall: 0000 8021 00 00 0040 00 C222 00 00 0000 00 00 A300, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:C222, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[A3, 00]]
dev:2712022-11-23 09:55:07.311debugGang en Voordeur buiten Gang en Voordeur buiten unprocessed EP: null cluster: null attrId: 0004
dev:2712022-11-23 09:55:07.303debugGang en Voordeur buiten Parsed: [raw:C22201000068040042105F545A333030305F6539386B7276766B0000002003010000205005000042065453303031320700003003FEFF003000, dni:C222, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZ3000_e98krvvk, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:50, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0012, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:2712022-11-23 09:55:07.213debugGang en Voordeur buiten sendZigbeeCommands received : [he raw 0xC222 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, zdo bind 0xC222 0x01 0x01 6 {A4C138A8AACF7A5B} {}, delay 2000, he cr 0xC222 0x01 6 0 16 0 600 {}, delay 2000, he rattr 0xC222 0x01 6 0 {}, delay 2000]
dev:2712022-11-23 09:55:07.208debugGang en Voordeur buiten configure().
