Device unknown
This device showed up and I don't know what it is. I don't remember seeing it before. It has no name or device driver. I'm I missing something? Should I delete?
Usuall the "Device" driver is used when troubleshooting a device that isn't working properly. Do you remember having a device you were troubleshooting and changed to the "Device" driver?
No. I have not been troubleshooting any devices. Can it be deleted. Or just leave it alone
Would be best to know what it actually is, first. :slight_smile:
The "Get Info" option on the Device page should at least identify if it's a Zigbee or Z-Wave device. Open a browser tab for Logs and then try hitting Get Info and see what comes up in logs.
You could also try confirming that all of your lights/switches, contact sensors etc., are working/reporting as expected. That is a bit of a PITA depending on how many you have.
You can also take a look at your Z-Wave Details page and see if you have any odd looking entries there.
Looks like Z-Wave. Still not sure what it is. Wait is a yolink device. No it's not my mistake.
You can try changing the driver back to Yolink (or whatever you use w/those devices). Then hit the "Configure" button on the Device page and then try the device control buttons (On/Off) or whatver it is/does and see what device it controls.
No. I misread the label. Not yolink
This is from zwave details
So it's a switch, "ACT" brand/type. (Not familiar w/that.
If you tend to only have one brand of switches, change the device driver to that driver you use w/those switches, hit "Configure" and then turn it on/off from the Device page and see which light responds.
If you have multiple switch brands/types, just try each type until you find something that works and something turns on/off from the controls on the Device page.
I changed it to genetic zwave switch and it shows it's off and I can't turn on. I don't remember buying ACT devices
From the inclusters it looks like it's a Z-Wave (not plus) switch, so try changing the driver to the same driver as other Z-Wave (non-plus) switches you are using in your home.
None of the drivers work. Just will not turn on
Odd...
Post a screen shot of the entire row for the device from your Z-Wave Details page.
@junk7001 A search of the company shows they make float switches and water sensors. Does that ring a bell?
No, not at all. I have none of that type device. Only Yolink leak sensors
Its like an easter egg hunt before easter.... :slight_smile: obviously its connected or you wouldn't have been able to get info from it. maybe look at what devices its using as repeaters...
How do I find that info?
Or how about I just leave it. All my zwave devices are working fine
i think i found it for you
https://www.smarthome-products.com/p-528-homepro-zdp100-z-wave-plug-in-lamp-module.aspx
HomePro ZDP100 plug-in Lamp Module
