Device topology incomplete
I have 19 Z-wave devices in my new Hubitat C-8 network. But when I do a "View device topology" from Settings, only 14 devices show up. The missing ones are all above node number 15. Three of them are battery powered sensors, two are in-wall light switches. What am I missing?
@Michele
Post your topology and post your z-wave details page in its entirety so we can look at it.
I hope this posts correctly.
Stats
Actions
0x0006 (6) PER: 0, RTT Avg: ms, LWR RSSI: 8dB
Neighbors: 2, Route Changes: 0
SPECIFIC_TYPE ROUTING_SENSOR_BINARY
Intermatic CA9000 motion detector None 01 -> 07 -> 06 9.6kbps 12/11/2024 11:46:01 pm
0x0007 (7) PER: 0, RTT Avg: ms, LWR RSSI: 17dB
Neighbors: 3, Route Changes: 0
GENERIC_TYPE SWITCH_BINARY
Intermatic Bathroom heater None 01 -> 0B -> 0D -> 09 -> 12 -> 07 9.6kbps 12/12/2024 9:30:02 am
0x0009 (9) PER: 0, RTT Avg: ms, LWR RSSI: N/A
GENERIC_TYPE SWITCH_MULTILEVEL
Intermatic Back porch light None 01 -> 09
0x000a (10) PER: 0, RTT Avg: ms, LWR RSSI: 14dB
Neighbors: 1, Route Changes: 0
SPECIFIC_TYPE POWER_SWITCH_BINARY
Jasco Products Shop light None 01 -> 09 -> 12 -> 07 -> 0A 9.6kbps 12/11/2024 1:35:11 pm
0x000b (11) PER: 0, RTT Avg: ms, LWR RSSI: 31dB
Intermatic Sump area light None 01 -> 0D -> 0B 9.6kbps 12/11/2024 10:56:59 am
0x000d (13) PER: 0, RTT Avg: ms, LWR RSSI: N/A
Neighbors: 6, Route Changes: 0
Intermatic Living room light None 01 -> 0D
0x000e (14) PER: 0, RTT Avg: ms, LWR RSSI: N/A
Intermatic Basement stairs None 01 -> 0E
0x000f (15) PER: 0, RTT Avg: ms, LWR RSSI: 12dB
SPECIFIC_TYPE ROUTING_SENSOR_MULTILEVEL
FortrezZ LLC Water leak alarm, water filter None 01 -> 0F 40kbps 12/12/2024 10:40:24 am
0x0010 (16) PER: 0, RTT Avg: ms, LWR RSSI: 13dB
Neighbors: 5, Route Changes: 0
Ecolink Garage door 1 position None 01 -> 10 40kbps 12/12/2024 1:14:41 am
0x0012 (18) PER: 0, RTT Avg: ms, LWR RSSI: 3dB
Neighbors: 4, Route Changes: 0
SPECIFIC_TYPE POWER_SWITCH_MULTILEVEL
Jasco Products Patio light garage side None 01 -> 12 40kbps 12/09/2024 1:52:58 pm
0x0013 (19) PER: 0, RTT Avg: ms, LWR RSSI: N/A
Wenzhou MTLC Electric Appliances Co.,Ltd. Upstairs landing light None 01 -> 13
0x0014 (20) PER: , RTT Avg: ms, LWR RSSI: N/A
Neighbors: undefined, Route Changes: undefined
Ecolink Garage door 2 position None 01 -> 14 40kbps 12/12/2024 6:45:39 am
0x0015 (21) PER: , RTT Avg: ms, LWR RSSI: N/A
Everspring Kitchen garage door sensor None 01 -> 15 40kbps 12/11/2024 4:58:18 pm
Can you post the page? Use windows snip... Want to see the entire page like this
Oh dear, I see the problem now. I was getting my device count from the Dashboard page. But that apparently includes my virtual devices (images, thermostats). So the topology map is actually correct and I'm very embarrassed. Doh!
