Device needs frequent re-configure
HI, I have a Jasco dimmer switch. The room has a motion rule that turns the switch on for 2 minutes whenever I walk through, and another rule to disable the motion rules if I physically turn the switch on (and enable motion when physically switched off.) The logic works as desired... as long as the switch correctly reports digital vs physical activation.
I'm using the community driver, and as long as I configure the device periodically, the switch reports correctly. But almost immediately, it will revert back to only reporting physical activation, even on motion rules or using a dashboard control. When I click configure, correct behavior returns.
I don't really know what configure is doing. I thought it was to match the Hubitat device page GUI to the options exposed by the driver, but it must be doing something more. What could be causing this device to un-configure itself periodically?
Device Id: 12855
Device Type: 18756
Driver: GE Enbrighten Z-Wave Smart Dimmer ver2.7.0 (latest)
2026-01-27 09:10:07.706 AM info gameRoomPucks was turned off [physical] #nope
2026-01-27 09:09:58.192 AM info gameRoomPucks is 99%
2026-01-27 09:09:58.187 AM info gameRoomPucks was turned on [digital]  #yup!
2026-01-27 09:09:39.749 AM info configure triggered
2026-01-27 09:09:03.856 AM info gameRoomPucks was turned off [physical]  # nope
2026-01-27 09:08:35.636 AM info gameRoomPucks is 99%
2026-01-27 09:08:35.631 AM info gameRoomPucks was turned on [physical] #nope
2026-01-27 09:06:04.326 AM info gameRoomPucks was turned off [physical] #nope
2026-01-27 09:06:03.370 AM info gameRoomPucks turned off [physical] #nope
2026-01-27 08:58:07.819 AM info gameRoomPucks is 99%
2026-01-27 08:58:07.814 AM info gameRoomPucks was turned on [physical] #nope
2026-01-26 05:52:12.414 PM info setting indicator behavior to LED ON When Switch OFF
2026-01-26 05:51:25.294 PM info gameRoomPucks was turned off [physical] #nope
2026-01-26 05:51:00.380 PM info gameRoomPucks is 99%
2026-01-26 05:51:00.374 PM info gameRoomPucks was turned on [digital] #yup!
2026-01-26 05:50:38.390 PM info configure triggered
2026-01-26 05:50:11.244 PM info gameRoomPucks was turned off [physical] #nope
2026-01-26 01:03:03.296 PM info gameRoomPucks is 99%
2026-01-26 01:03:03.290 PM info gameRoomPucks was turned on [physical] #nope
